Cam this Nova
Old 04-24-2012, 07:49 PM
livewire0201's Avatar
Default Cam this Nova
Hey Guys/Gals,
After weeks of researching I still cannot find a cam I can bring myself to purchase. This is going into a stock 98' ls1.
The car is a 62 nova, full cage, t56, Jag IRS.
My Plans:
Cruise this summer. I want a driver with more than stock power. In the future (this next winter) I wish to turbo. I am at school and have no available tuning shops. I do eventually plan on doing the tuning on my own. (Getting my masters in Engineering)
Therefore, I want a cam that makes good power in the upper rpm range, has the possibility of accommodating turbo(s), can drive reasonably on stock tune, and not have ptv worries.
Parts I have now. Jesel Shaft mount rockers, .650 springs with ti retainers, rod bolts, oil pump, timing chain, pushrods will be ordered when length is determined, various gaskets. I can get a set of 241 heads for free, "good" heads will be a year or so down the road as well as intake.
I autocross, beat the living sh*t out of it, and want to see some road course action eventually.
ls6 cams seem to work well with turbo's but I am afraid I will be unimpressed and regret it. I want something with usable power to around 7000.
Thanks!
Old 04-24-2012, 07:58 PM
HAHA I 1's Avatar
I like your choice in cars and engines.
Old 04-24-2012, 08:38 PM
Whiteaw57's Avatar
any idea how much it weighs? and are you willing to upgrade the clutch (or does it have one)
Old 04-24-2012, 08:43 PM
I'm guessing its right around 3000. It's a centerforce clutch
Old 04-24-2012, 09:25 PM
HeavyMetl's Avatar
I think I'd call EPS or Texas Speed for a recommendation. That's one awesome build you've got there, and if you're like me coming from old-school SBC's you'll never look back.
Old 04-25-2012, 12:30 AM
99Bluz28's Avatar
I'd also post in the Forced-Induction section.
https://ls1tech.com/forums/forced-induction-9/
Regardless of which cam you go with I'd at least get a mail order tune.
Old 04-25-2012, 11:37 AM
Looks like I'll be doing a mail order tune as well. Looking for around 400 horse. What are the limits on lift for stock heads, clearance, etc.?
Old 04-25-2012, 01:32 PM
Shockwave179's Avatar
Lunati Voodoo Hyd Roller Cam - LS1 LS2 272/278
Hydraulic roller. Great street performance choice. Very strong HP increase above 3500 RPM with proper computer tuning. Very drivable with excellent street manners. Works well with 5.3-6.0 liter engines.
Advertised Duration (Int/Exh): 272/278
Duration @ .050 (Int/Exh): 222/228
Gross Valve Lift (Int/Exh): .567"/.567"
LSA/ICL: 113/109
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 2000-6600
Includes: Cam Only
Part Number: 60511
Old 04-25-2012, 02:41 PM
99Bluz28's Avatar
Since you wanting around 400rwhp and go turbo with the same cam it's going to be a compromise. You don't want to go too big since you'll want to keep the overlap down for the turbo, now if that 400hp is at the flywheel that shouldn't be a problem.
BTW if you're willing to go with more aggressive lobes you'll get more power out of a smaller cam.A good option is to go with some Comp Cams LXL lobes (boost friendly),maybe like a 226(.605")/226(.605") 114lsa. That'll keep overlap down (-2*), and will still make good power before the turbo build.
Or the option I sent in you PM.
Old 04-25-2012, 03:45 PM
^^^ this is a possibility. I was thinking about the SpeedInc Tu1. Any thoughts on that grind?
Old 04-25-2012, 04:54 PM
Z28SteveA4's Avatar
you. must. post. more. picture!!! Sweet build man im so jealous. Sorry not enough experience with turbo cams to make a good call for you but the cam right above seems like it would work well for your setup. I dont think that cam will make power to 7000 like you want.
Old 04-25-2012, 05:39 PM
99Bluz28's Avatar
Yeah, with that cam I'd run it advances 2-4* for now, then when you get the turbo on run it straight-up with no advance and that'll bring you power band up 100-200rpm. I'm not sure what lobes the SI TU1 uses (possibly XER), but(IMO) I'm sure the LXL lobes would most likely work better.
Old 04-25-2012, 05:46 PM
99Bluz28's Avatar
Well that also depends on how well his intake and heads flow, my 227/231 111+2 lsa cam can pull to 7k with very little hp drop.
Quick Reply: Cam this Nova
