Gears & Axles - Question about drive v6 driveshaft.
bad_408_vert
04-26-2012, 08:30 AM
I'm doing a v6 to v8 swap.
So my question is if I can use the 3.8l v6 driveshaft with v8 drivetrain?
k_cash1432
04-26-2012, 12:01 PM
You can use it but your better off upgrading it all now while you have it out. The rearend would be the only thing to reuse since they are the same 10 bolt rearend and I'm changing mine to an 8.8 when I get my hands on one
bad_408_vert
04-26-2012, 01:54 PM
^ Thanks for confirmation.
If the v6 can work, which is made out of steel .
Wouldn't that be upgrade since lot of high hp car owners end up swapping form aluminum DS to a steel one anyway?
t/a98
04-26-2012, 03:11 PM
They go to a much stronger chromoly. Better balancing and larger u joints. Stock is fine but when you make any power and bow your driveshaft and destroy your tail housing you'll see why people upgrade the driveshaft.
FirstYrLS1Z
04-26-2012, 04:46 PM
V6 driveshafts are 2 piece,V8 driveshafts are 1 piece.
bad_408_vert
04-27-2012, 09:56 AM
Alright, will defintely need a DS from a v8 then.
Thanks guys
bwkmaro
04-27-2012, 05:01 PM
v6's stopped with 2 piece ds in 1998
lsxformie
05-01-2012, 10:22 AM
^^^^What he said.
cemlsx
05-01-2012, 11:11 AM
Correct , they are all interchangeable.. I currently run a one piece aluminium on my V6 ..
