double roller timing chain for use with 24x system
ya but the guy above you t/a kid did it with the use of a efi 24x reluctor wheel. WHich efi24x says cant happen, which is why they sell the billet timing cover.
Yes, you are correct.
From experience, I will never recommend moving the crank sensor forward (two timing cover gaskets will move the crank sensor forward). This has bad news written all over it. If it works for you, then great (but I will never recommend it).
The "bad news" includes...
- discovering that there is no clearance available with a double row timing set, the GM timing cover, and any reluctor (I've discussed this many times in other posts)
- phone calls and email from customers who have used a double row timing set and report a no start, no spark condition
- generally the only installations that have a no start, no spark condition are the ones using aftermarket timing sets that change the geometry that GM designed (in orther words the crank and/or cam timing sprockets are too thick)
- bench testing to see where the sensor "reads' and does not "read" from the reluctor (again, I would advise against moving the sensor forward)
