Turbo Sizing Question.
I have a friend that is going to be putting a turbo on a LS2 and was wondering if this turbo he is looking at is too small? I though it looked too small especially with the T3 turbine. It is going to be a front mount. What are your opinions? It will be intended as a low boost application to spool quickly on the street.
Turbo specs:
Compressor: 4" inlet, 2.5" outlet
Turbine: T3 flange, 3" V-band
Compressor: .70a/r
Turbine: .84 a/r
Compressor Wheel: 91mm/61mm
Turbine Wheel: 74.7mm/62mm
Turbo specs:
Compressor: .70a/r
Turbine: .84 a/r
