Conversions & Hybrids - S10 Xtreme L33 swap!
zdiesel
04-27-2012, 11:40 PM
So getting ready to start my first LS swap and figured I would start a project thread. So here's the patient...
http://i1185.photobucket.com/albums/z343/zdiesel123/2011-09-17_17-52-55_129.jpg
And here's a link to my other build thread in the member's projects section on S10 forum if people want to see what has been done to the truck so far: http://www.s10forum.com/forum/f30/project-daily-driven-xtreme-430592/
And here's what came in today :D
L33 with 29k miles and a 4L60e with 40k miles on it
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-04-27_17-57-07_548.jpg
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-04-27_17-54-17_881.jpg
Other part's on the way:
- 98-99 F-Body manifolds
- Superior aluminum S10 V8 swap radiator
- Dorman 300-201 power steering pump pulley
And some other part's I've pulled so far from the junkyard...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-04-21_15-03-31_547.jpg
- Blazer auto console
- Cable driven throttle body
- engine cover
- 4.3 throttle cable
zdiesel
05-05-2012, 11:47 PM
Well, I'm home for summer now, thank god! Unwrapped the engine to check it out, some pics...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-05-05_23-13-20_516.jpg
799 Heads
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-05-05_23-12-35_607.jpg
Anyone know what this is? Looks to be broken off...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-05-05_23-08-30_415.jpg
Superior Performance swap radiator...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-05-05_23-52-34_392.jpg
Dorman PS pump pulley...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-05-05_23-55-22_823.jpg
SIKHS 5
05-06-2012, 12:53 AM
dont worry about the broken part, it's a super easy to replace - if you're using a hydroboost setup on your s10 just buy a new plug for it if this one isn't sealing - if you're using a traditional brake boost you will need to run your vacuum line to this location(i personally used a plug that i drilled through and epoxied a 90degree barb to - then pushed the vacuum hose onto that)
to remove the broken plug, push back the red part with your nail, hold it back and just slip out the plug (water coolers and some refrigerators use this same type connectors for their waterlines)
speedfreak90
05-06-2012, 07:16 AM
looks good so far!
oldgoat69
05-06-2012, 07:34 AM
I will be following this one. I am planning a similar swap for my 2000 S10. It will be a daily driver 4.8 4L60E.
andrew69_04
05-06-2012, 10:17 PM
i did one of these swaps a few years ago in my 03 xtreme. I must say, for a DD, it was super fun to drive!
5.3blazer
05-07-2012, 12:18 PM
looking good so far,will be a fun dd when done
zdiesel
05-07-2012, 07:09 PM
Thanks!
Some progress made today, got the engine onto an engine stand and pulled the wiring, exhaust manifolds, and some other junk off.
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-05-07_16-24-24_61.jpg
pulled the DBW throttle body off and cleaned up the DBC cable I pulled at the junkyard and went to put it one where I ran into my first issue...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-05-07_18-06-20_556.jpg
Can that vacuum connection on the intake manifold be removed and replaced with some sort of plug or do I need a different throttle body? Or a different intake manifold?
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-05-07_16-24-29_498.jpg
Any one need a wiring harness and PCM for a DBW swap? I'll be posting it in the classifieds here soon.
zdiesel
05-08-2012, 09:07 PM
fixed the throttle body issue...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-05-08_14-15-23_290.jpg
Pulled the valve covers off to clean them up today, motor looks clean on the inside!
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-05-08_14-15-11_530.jpg
Anybody wanna guess what this 4L60e is out of? Cause I don't know...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-05-08_13-09-18_830.jpg
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-05-08_13-08-59_38.jpg
Motor all cleaned up...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-05-08_20-09-58_998.jpg
Shattered my new PS pump pulley putting it on :bang:
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-05-08_19-23-47_51.jpg
New one on the way already, was my own stupid fault. Was using a bolt and a socket to pull the pulley onto the shaft of the pump, had the socket resting on the plastic part of the pulley rather than the metal part, impact gun caused it to shatter. Live and learn.
Ordered my wiring harness and ECM/programming from CPW today! :D Also thinking about smoothing the truck intake, any thoughts on that?
zdiesel
05-09-2012, 01:36 AM
Did some digging, the code on the sticker on the trans is 9LHD which turns out to be a 1999 GMC VAN G2500 5.7 Cyl 4L60E
Correct me if I'm wrong but that's a non LS motor, will this still bolt up to my L33 properly?
TTLS1GP
05-09-2012, 02:07 PM
yes it will bolt up but IIRC you will need the spacer for the Torque Converter spud.
The electronics might be different too. Not sure. I think S&P has a writeup on how to make it work.
zdiesel
05-09-2012, 06:53 PM
Thanks for the reply, guess I'll have to do some digging unless someone else wants to chime in on the issue.
zdiesel
05-24-2012, 12:14 PM
Sold off the auto trans in search of a T56, had a lead on one but it was bought out from under me, so the hunt continues. Not much going on in terms of progress, waiting on my wiring harness. Motor mounts are on the way, may hit the junkyard later today, I'll be sure to post up with any scores!
Steve01SS
05-24-2012, 07:46 PM
Nice truck. I will be subscribing to this post. I have an S10 with a 4.3 that I'd like to do a swap in. I really like that radiator.
BTW, I have the same blazer style console and shifter as you have in the pics. Plan on installing that over the holiday weekend. Already have blazer seats in the truck.
99VetteFRC
05-24-2012, 08:11 PM
You should check the throttle body to manifold mating surfaces. I found I had to fill the back of the TB with silicone for the vent tubes. It would have caused a serious vaccuum leak. I put a DBW TB on a 99 LS1 intake. The vent on the truck intake goed through a small hole in the TB and gets air before the TB blade. Cable TH gets vent through the port you plugged. Just some info for you to double check.
zdiesel
05-24-2012, 10:53 PM
I hadn't thought of that, I'll have to double check that, thanks!
Nice! The radiator is a pretty slick deal, and a good alternative to the $500 CPW radiator that doesn't have a built in trans cooler. It's a direct fit for the first gens, and will fit in second generation S10's core supports with some trimming in the corners on the core support.
zdiesel
05-26-2012, 10:01 PM
Small update...went to the junkyard the other day and grabbed some small stuff, couple bolts, radiator cap, upper radiator hose from a 5.3 silverado (for test fitting), and the brake booster nipple that was broken on my intake. Also pulled some threaded inserts out of an intake for my intake manifold since the L33's came DBW and I'm going DBC.
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-05-25_11-20-50_148.jpg
Pressed them in...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-05-25_11-24-55_365.jpg
Got my 98-99 F-Body manifolds I bought off of blackphantom (excellent seller by the way, very fast shipping!)
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-05-26_12-42-35_204.jpg
Chris Thompson
05-30-2012, 05:46 AM
What do you want for the harness and ecm for the dbw?
zdiesel
05-31-2012, 12:09 AM
PM'd...
small progress, pulled the intake back off to seal the knock sensors with silicone...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-05-30_18-53-45_287.jpg
Then my CPW motor mounts came in...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-05-31_00-10-44_866.jpg
Bumpin' Yota
05-31-2012, 06:43 AM
Why did you put silicone around the knock sensor seals?
that's to keep water out. if it gets in there it rots the sensors and harness. good practice whenever they are exposed for service.
TypeSL2
05-31-2012, 08:48 AM
The engine I got had a knock sensor that was rotted badly because of water intrusion. Was a bitch to get out, but luckily no permanent damage to any of the motor. Just had a little corrosion to clean up and a new sensor to buy.
James
zdiesel
05-31-2012, 11:07 AM
^ bingo.
b.t.s
06-01-2012, 06:05 PM
subscribing
Bumpin' Yota
06-06-2012, 08:51 AM
updates?
Troy5061
06-06-2012, 09:03 AM
I have some exhaust manifolds off my 2001 that don't have the goofy looking egr port sticking up I would have given to ya lol:cheers:
zdiesel
06-06-2012, 12:58 PM
Needed the 98-99 style manifold to cut the flange off and weld a tube on since the flange would hit the frame rail, and the 00-02 style are cast iron I believe, makes them harder to weld to supposedly. Thanks though! Up in winterport huh? I'll probably try and make it to winterport dragway when I head back up that way in the fall for school if it's still open.
No more updates as of yet. New AC compressor is in the mail since the one that came with the pullout was damaged. I've also done some rationalizing and realized I can afford a T56 just yet, so I picked up another 4L60e. Will post pics of that later tonight I suppose, nothing special. Stock 4L60e out of an 04 5.3 Silverado with 30k on it. Corvetter servo is also in the mail. Wiring harness is 6 weeks out, and I start work in a week here so the money will start pouring in as will the parts! :cheers:
zdiesel
06-06-2012, 09:58 PM
New trans, gotta clean up some of the corrosion off the case.
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-06-06_21-27-28_782.jpg
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-06-06_21-27-12_911.jpg
Corvette servo came in...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-06-06_22-28-15_475.jpg
ch0425
06-13-2012, 11:48 AM
Keep up the good work, my s10 has come to a halt since im taking summer classes to catch up.
zdiesel
06-26-2012, 10:35 AM
So I snagged this banner when I went to the Goodguys Northeast show, even though I don't own anything from them...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-06-26_11-02-28_247.jpg
...but now I do...:rolleyes:
zdiesel
06-27-2012, 07:26 PM
No one picked up on that apparently.
This morning I turned this...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-06-27_07-12-05_307.jpg
Into this...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-06-27_16-07-59_419.jpg
M12 out of an 04 GTO with 45k miles on it, complete with an f-body hurst shifter, flywheel, clutch, all hydraulics, and starter. Thank god I don't have to run an auto haha
99VetteFRC
06-27-2012, 08:03 PM
You may want to try a 99-02 truck intake, they were cable driven TB and my work with your TB.
zdiesel
06-27-2012, 08:58 PM
I checked out the two throttle bodies and the intake manifold and I can't see where a vacuum leak might occur, so I think it should be fine as is...
DBW TB:
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-05-29_20-18-26_426.jpg
DBC TB:
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-05-29_20-18-19_647.jpg
Intake and two TB's:
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-05-29_20-18-08_762.jpg
Am I missing something? I don't see where a vacuum leak would occur.
99VetteFRC
06-28-2012, 04:57 AM
DBW TB:
DBC TB:
I did the opposite, put a DBW on an LS1 intake and the ports are a little different. Your set up doesn't look like you will have that problem.
Charlville
07-01-2012, 10:52 AM
Hi
I'm over in the UK and considering the same swap, so this thread is great :)
speedtigger
07-01-2012, 11:58 AM
I had a 99 xtreme. I really like that little truck. This looks like a great swap.
slowsol95
07-01-2012, 04:20 PM
Its coming along, the worst part about the stage your (and me) at is having to look at all these cool parts you bought and not being able to put them in. Looks good, you"ll have to check out my swap thread too.
zdiesel
07-01-2012, 10:32 PM
It really is though haha, I may or may have not been sitting on the floor of the shop the other day pretending I was driving it while shifting the T56.
I'm only 20...20 year olds still play imaginary race car right?...right? :burn:
Either way, I'm glad other's find my thread useful. Paying off some loans, parts should start flying through the door in a few weeks first of which my oil pan so i can pull the 2.2 and get this L33 fitted in the truck. I'll have to pick up some steel for my notches.
hotrodscrap
07-01-2012, 11:07 PM
Cool looking build man, you keeping all the creature comforts, a/c, and heat? I'll be lurking, good luck!
-SS
zdiesel
07-02-2012, 09:08 AM
Yup, keeping both AC and heat! She's my daily so both are pretty necessary.
hotrodscrap
07-02-2012, 11:50 AM
Good choice, I'm sub'in for updates. Keep em' coming!
-SS
bamaballa205
07-10-2012, 03:12 AM
5.3 Were made for these trucks.
zdiesel
07-17-2012, 10:30 PM
Alright, so got some parts in.
Holley Oil pan...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-07-17_20-40-24_737.jpg
Parts from Summit; Fuel line, AN fittings, oil filter, oil pan gasket, dipstick, dipstick tube, and clutch alignment tool. Also got my bronze pilot bushing in.
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-07-17_22-34-21_396.jpg
Part numbers for fuel fitting for 2.2 flex fuel truck (need two of the straight hose ends)...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-07-17_22-33-29_593.jpg
Flywheel resurfaced and spacer for it...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-07-17_22-36-56_887.jpg
And then hit a road block, pulled the pan off and fitted the pickup tube, windage tray only needed some small filing for the pickup bracket to clear. And then I was looking around and I noticed this...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-07-17_21-18-28_748.jpg
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-07-17_21-18-36_317.jpg
Crack in the block where the starter mounts, pretty upset about it. Calling up my machinist tomorrow to see when I can get it to him to weld up. Truck starts coming apart this weekend.
Crazier
07-17-2012, 10:45 PM
Nice crack :P
I will be watching cus l33 seems to be rare on this forum, yours is a lot lower miles then mine though, wanna trade?
zdiesel
07-18-2012, 11:18 PM
I've seen a lot more L33 builds starting to surface lately. No trade, this puppy is all mine :) I hunted for a while to find a good low mileage pull out.
Engine is loaded up in the back of the truck, heading to the welder in the AM to get the crack fixed. On another note, I've ordered my air intake, mufflers, and my wiring harness should be coming in any day :hump:
Crazier
07-18-2012, 11:54 PM
Prices seem to be coming down on the l33. in reality I think they were far overpriced, unless your really cutting pounds they arent much better then any other 5.3. whats 150 lbs in a 3000 lb 350 horse set up?
Cept, its jsut cool to have one :P
bamaballa205
07-19-2012, 01:45 AM
Damn that crack sucks.
zdiesel
07-21-2012, 11:11 PM
Some updated from the past few days, things are starting to get rolling here.
Crack has been welded up...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-07-19_20-29-33_210.jpg
Replaced the rear main seal gaskets since they were in such close proximity to the welding.
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-07-19_20-29-56_623.jpg
Got my Holley oil pan bolted up...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-07-21_19-06-26_424.jpg
Then I threw the truck on stands, and the fun begins. :D
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-07-21_17-00-26_840.jpg
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-07-21_17-00-07_106.jpg
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-07-21_17-00-47_345.jpg
And here's how she sits at the end of the day.
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-07-21_23-25-53_374.jpg
Doesn't look like much but the exhaust is off, driveshaft is out, whole front faschia is off, fluids drained. Hoping to get the engine pulled out before next weekend.
ch0425
07-22-2012, 10:21 AM
Great build, what A/C compressor are you using?
zdiesel
07-22-2012, 06:02 PM
You can sort of see it in the picture of the oil pan on the engine. It's a Denso compressor from the Silverado it was pulled out from. The fittings attach a little more forward then like an fbody compressor, which helps them clear the control arm, the f-body ones tend to interfere with the control arm. If you want me to get a better picture of it or part numbers for you I can, just let me know.
ch0425
07-23-2012, 08:20 PM
The part number would be great, i would like to mount the compressor up top but i have the alternator there so im going to have to pull the engine back out to notch the frame.
zdiesel
07-24-2012, 12:18 AM
15244321, that number is on the front of the pulley and what I used to search for an AC compressor on ebay. My pullout came with the same one but it was mangled. Here's a shot of some other part numbers...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-05-05_23-09-53_369.jpg
And time for an update.
Who likes progress?
I know I do...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-07-24_00-24-09_151.jpg
Finally after 3 hours we wrestled that pile of scrap metal GM calls an engine out. Next thing to do is give the engine bay a cleaning and work on cutting my AC notch.
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-07-24_00-23-19_55.jpg
Part's will be flying through the door all week for this. Got some new stuff now though. eBay Silverado intake, saw someone else use it so I figured I'd give it a go.
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-07-24_00-26-38_542.jpg
Catalytic converters...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-07-24_00-25-49_876.jpg
but not really :D
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-07-24_00-26-11_205.jpg
ch0425
07-24-2012, 05:08 PM
i appreciate the part number and picture!
zdiesel
07-25-2012, 11:47 PM
Not a problem!
Wiring harness came in...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-07-25_22-58-44_686.jpg
zdiesel
07-26-2012, 10:33 PM
Got some stuff done between work shifts this week. Pulled it outside and hit the engine compartment with a tonnnn of foaming degreaser haha...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-07-26_11-32-46_390.jpg
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-07-26_11-32-53_363.jpg
Looks a lot cleaner now.
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-07-26_12-12-44_132.jpg
Started pulling the interior out, will finish that up tomorrow AM.
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-07-26_12-12-23_461.jpg
And my magnaflow mufflers and T56 speed bleeder came in. Went for two 18" case magnaflows, the speed bleeder is from Speedway USA, was half the price of the tick performance unit, doesn't have the check valve though so I'll have to bleed it like you would brakes, but it makes it a hell of a lot easier to reach haha and I couldn't justify $60 for a speed bleeder I'll probably use only a handful of times. I'll save the money and just get a friend to help me lol
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-07-26_19-38-20_271.jpg
zdiesel
07-30-2012, 09:23 PM
Small update. Got some parts in...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-07-29_10-14-30_771.jpg
LPW Girdle, and some stainless v-band's with mild steel flanges for my modifying my manifolds.
Test fitted the motor, k-member does need to be notched with the holley pan, started that notch and need to start my AC notch, no pictures of that progress as of yet though.
zdiesel
08-04-2012, 08:53 PM
Got some more parts in! Two e-fans, and a battery relocate kit to put the battery in the bed.
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-08-02_11-05-05_219.jpg
Picture of my notch cut k-member.
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-08-02_12-18-04_252.jpg
Spent the day cutting up the plate, man do I need a bansaw. Welded it up, thought I did damn well for first time actually welding up a frame! Need to still cut the side pieces out and weld those in, going to do that tomorrow and start cutting the AC notch.
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-08-04_20-43-40_164.jpg
Fitted the engine to check oil pan clearance and mark for my ac notch. Oil pan has much more room now, I'll take pictures and post some of the pan clearance when I get the motor back in to test fit the AC notch clearance.
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-08-04_19-52-04_648.jpg
Finished pulling my interior out to, gonna work on a cover panel for the old shifter location tomorrow. Clutch and flywheel are on the engine now and the trans will be bolted up next time it goes in as well so I can cut the new shifter location.
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-08-02_12-18-33_79.jpg
blknSS
08-04-2012, 09:06 PM
Nice, should be a fun truck. What part of Maine? I've live all over that state except far north.
zdiesel
08-04-2012, 10:08 PM
Falmouth right now, up in Orono when I'm at college.
zdiesel
08-09-2012, 10:17 PM
Progress has been slow last few days. Finished my oil pan notch...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-08-07_20-46-41_298.jpg
And started cutting and test fitting for the AC notch.
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-08-07_20-46-17_287.jpg
Money is starting to run real low on this project, and I'm starting to think about putting the 4 cylinder back in to run it until I come home for winter break from school. It would give me more time and money to buy the things I want like tubular uppers, BRP longtubes, Blazer gas tank, and get my Posi unit installed (bought a zexel torsen, no pics as of right now but may sell to get an auburn instead). I've got just about everything I need to get this in and running, but I'm not crazy about the f-body manifolds and I still need to throw $500-800 at it to get an exhaust built and another $100-150 for the driveshaft modifications to at least get it driving. To what, then swap out the exhaust manifolds and need to re-work my exhaust and have to put a new exhaust on it because of the blazer tank swap. Just seems much more logical to me to just get all my notches done and the motor fit, and then put the 2.2 back in until winter break so I can bank some and get more parts and then do it right.
zdiesel
08-11-2012, 05:33 PM
I got some work done today, my trans corss member came in yesterday. So I bolted up the T56 to the engine and fitted the engine. For those wondering, I couldn't get the engine and trans in together, I left the bell housing attached to the block and seperated the transmission, installed the engine and then bolted the trans back up. I also had to pound the lip around the trans tunnel for clearance to get it to fit. If I had done that before hand I may have been able to get the whole package in as one.
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-08-11_14-40-25_331.jpg
Bought it from a member on S10Forum, it really fit well, only had to elongate the trans mount hole for some wiggle room.
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-08-11_14-40-02_326.jpg
New placement of shifter, have to make a plate to cover up old one and cut the new one.
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-08-11_14-43-18_277.jpg
Test fitted driveshaft, just barely doesn't fit. So I'll have to get that cut.
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-08-11_15-11-32_996.jpg
Worked on the AC notch some more and fitting.
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-08-11_14-42-49_979.jpg
Need to angle the notch a bit more to clear the pulley some more. it's tight.
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-08-11_14-42-57_779.jpg
Then modified the idler arm for extra clearance, I need to replace it so this was a mockup one, but I took a bolt and put it on the lathe and rounded the head, drilled a new hole and welded in the bolt and then ground it flush. Also cut it shorter, it came out really good.
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-08-11_16-41-46_523.jpg
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-08-11_16-42-33_38.jpg
milktasd
08-11-2012, 08:47 PM
Looks
zdiesel
08-20-2012, 07:31 PM
Here's some pictures of my oil pan clearance with the notch for anyone who wants to reference. CPW poly mounts with the engine all the way forward. Much better, don't know how anyone would be able to run this pan without a notch or some heavy firewall work.
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-08-18_21-29-24_720.jpg
Started working on the core support, trimmed the corners and the upper lip to fit radiator inside, welded back up and ground down. Two plates welded on bottom for mounting points on radiator.
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-08-18_17-25-25_277.jpg
List of crap to do!
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-08-18_14-57-40_508.jpg
Core support painted up, and condensor fit, I put foam on both sides of the condensor and didn't use the stock rubber mounts.
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-08-20_17-05-53_136.jpg
Painted radiator...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-08-20_17-05-19_832.jpg
Andddd core support all done, condensor, radiator, and e-fans mounted. Looking at it now I probably didn't save any room over a stock 4.3 rad but this radiator is a hell of a lot beefier haha, shouldn't have any cooling problems. I'm really enjoying learning and working on my fabrication skills as well, definitely need to do more of it.
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-08-20_18-30-48_590.jpg
Trimmed up the stock fan shroud to make it look a little cleaner, still has the 2.2 sticker on it lol
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-08-20_18-30-59_683.jpg
Dropped my driveshaft off to get shortened today, taking 1.5" out of it. Measured 51.5" center to center.
LilJayV10
08-20-2012, 08:17 PM
I would pin that idler arm or something. With as much force that gets put against it when you turn, with only one bolt its probably going to rotate. Keep up the good work.
zdiesel
08-20-2012, 08:39 PM
Take another look at it...two bolts. Well, one stud and one bolt technically. ;)
LilJayV10
08-20-2012, 10:04 PM
Well crap I didn't see the pic above it. :doh:
Carry on. :)
54inches
08-20-2012, 10:30 PM
I would test fit the speedway bleeder right now as it did not work on my LS7 Slave going in my V, but it might work for an earlier model T56.
zdiesel
08-21-2012, 01:49 AM
It's already on, no problems. Thanks for the heads up though.
54inches
08-21-2012, 07:45 PM
10-4!
Kory 88Iroc Lt1
08-22-2012, 10:19 PM
I probably missed this, where was the radiator from. How much was it? Nice build btw.
Thanks,
Kory
01WS6/tamu
08-22-2012, 11:17 PM
Do yourself a favor and measure your radiator core and see if you can find a OE fan setup from a front wheel drive car. Aftermarket fans suck and just dont last.
I used a flexalite 210 fan setup on my 6.0 sonoma and had a fan fail on power tour effectively putting a crimp in the trip. I finally found a set for a 03 chrysler 300 that fit my particular setup and the cooling performance and reliability is day and night.
Just saw you are from maine it never gets hot there you may be ok but might still consider the above recommendation.
zdiesel
08-22-2012, 11:48 PM
Radiator is from Superior Radiator, I got it for $300 shipped, was cheaper then the CPW $500 radiator, but also required a lot more fabrication in terms of mounting solution. Turned out it's actually designed for a first gen S10 lol
I've been keeping my eye out at the junkyard for some e-fans, I agree though. These were mad cheap fans, like $45 a piece. They'll get me by for now, and with that big radiator in the winter, shouldn't have a problem with heating issues lol
Freeman83
08-22-2012, 11:56 PM
Great build man!
01WS6/tamu
08-23-2012, 02:16 AM
You should definitely be covered on cooling capacity for the winter. Yeah I think I'll pass on your winter its too cold for me when it gets into the 50's here. I'll take 110 degrees any day
zdiesel
08-23-2012, 05:56 PM
110 degrees and I turn into a hermit next to my AC unit haha
As much as I complain about the cold during the winter, I actually enjoy it.
akasquirt01
08-24-2012, 10:50 PM
i may have missed it but were did you get the oil pan and what was the part # on it im getting parts together to start on my 94 4.3 to a 6.0 swap im going to be following your build looks good
zdiesel
08-25-2012, 08:39 PM
http://www.autopartsway.com/PartDetails.cfm?302-1/H19/search:oil_pan
Best deal around, fast shipping, no problems.
Finished my AC notch, don't make fun of my welding... lol
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-08-23_20-13-46_859.jpg
Motor in for good hopefully.
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-08-25_20-35-59_165.jpg
Modified the AC compressor a little bit, front bottom bolt was real close to the frame, so I cut down the mount and used a smaller bolt. Fits mint now...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-08-25_20-36-08_604.jpg
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-08-25_13-27-48_121.jpg
Cut the hole for the shifter...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-08-25_20-35-38_979.jpg
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-08-25_20-35-48_455.jpg
Repainted the cross member, got my drive shaft back from being cut.
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-08-25_20-36-28_330.jpg
Started fitting my fuel line, turns out both my fuel rail, and fuel filter are 3/8" and I ordered 3/8 and 5/16 quick connects, so ordered another fitting to finish that up.
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-08-25_20-38-06_776.jpg
I really didn't like the F-Body manifolds, so I broke down and bought a set of coated sanderson headers, those should be here wednesday.
zdiesel
08-28-2012, 10:24 PM
Getting alot of the small stuff done past few days...
Core support back in place, power steering lines all modified and connected. I used the stock 2.2 high pressure line and just rebent the metal tube until it cleared. Started running the wiring harness and connecting things. Headers, shifter boot, plug wires, and new fuel connector show up tomorrow.
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-08-28_11-36-39_690.jpg
Relocated the battery to the rear, ran all the wires. The biggest pain in the ass though has been finding a way to wire the positive cable into everything together in a simple way, does anyone have suggestions?
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-08-27_21-01-24_648.jpg
And lastly, wtf is this connector?
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-08-28_22-50-14_92.jpg
It looks like its suppose to plug into this plug (not the cam position sensor but the tall one), but it doesn't fit. I'm lost.
http://image.superchevy.com/f/technical/engines_drivetrain/17692404%2Bw193/sucp_0902_24_z%2Bsmall_block_chevy_engine_timing_c ontrol%2Bcam_crank_position_sensor.jpg
01WS6/tamu
08-29-2012, 04:01 PM
oil pressure sending unit.
I put the battery in the bed on my swap inside a tool box. I used 0/0 cable and ran it to the front and used made the run from the battery to starter in one piece of solid cable. I then took it to a truck shop that makes cables for big trucks and we used a crimp shell they put around the cable before it got to the starter and essentially y'd the cable and ran a loop forward that went up to the power distribution center and put another crimp shell and y connection and made a drop to the alternator.
I ran a 0/0 ground from the battery to the frame. and then a 0/0 ground from frame to block and a 2 gauge ground from block to firewall ground, the cab to frame ground and block to core support ground.
zdiesel
08-30-2012, 12:28 PM
Yup, turns out I need a different sensor. On order from the dealership now.
Sandersons showed up...
http://i1185.photobucket.com/albums/z343/zdiesel123/538470_10151053631127308_438270451_n.jpg
01WS6/tamu
08-30-2012, 07:10 PM
You'll like them. Mine have been on my sonoma bout 40K miles now and not a leak one from them. I used OE gm gaskets with locking header bolts. Then used copper gaskets and knurled aircraft lockuts on the collector.
zdiesel
09-03-2012, 12:06 AM
Well, its been a good weekend of work.
Correct oil pressure sensor installed...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-09-02_11-32-39_77.jpg
Picture of fan to accessory clearance. Plenty of room...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-09-02_11-32-22_858.jpg
Set it back on the ground, stance appears to be the same...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-09-02_11-31-57_46.jpg
New shift boot...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-09-02_11-31-18_84.jpg
Interior going back together...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-09-02_11-31-25_662.jpg
Hood back on...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-09-02_15-24-46_626.jpg
Got my headers on, real tight clearance. Definitely ordering some tubular uppers and going to have to do something about the steering shaft...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-09-02_11-30-48_536.jpg
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-09-02_11-31-02_855.jpg
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-09-02_11-30-34_383.jpg
Oh and then we finished up some wiring, my fuel lines, and did this.
http://i1185.photobucket.com/albums/z343/zdiesel123/th_2012-09-02_14-24-31_330.jpg (http://s1185.photobucket.com/albums/z343/zdiesel123/?action=view¤t=2012-09-02_14-24-31_330.mp4)
Goat2NV
09-03-2012, 07:15 PM
Man thats real nice! Cool swap.
01WS6/tamu
09-04-2012, 11:42 AM
I stuck with stock uppers on mine. Pull the header back off get a bmfh and whack it till you have the clearance. I didn't have to get too crazy with a hammer on mine and they dont rub a bit.
zdiesel
09-04-2012, 08:25 PM
I already grinded a llot of material off and don't want to do to much more. So I said F it and ordered a set of UMI upper control arms with tall ball joints. Should be showing up in a couple weeks. Pretty pumped.
01WS6/tamu
09-05-2012, 01:14 AM
How much they set you back. My poly bushings are about toast from heat so sounds like a worthwhile upgrade.
1970 LSCamaro
09-05-2012, 01:09 PM
Truck is looking good....otta run well
zdiesel
09-05-2012, 01:42 PM
The sale is over, I got the upper's complete with tall ball joints and new hardware for $430 shipped. Would cost you around $480 shipped now for everything. You can get just the arms without ball joints and hardware for $340 + shipping.
01WS6/tamu
09-05-2012, 06:12 PM
What advantage does the tall ball joint give a better caster camber curve for cornering?
zdiesel
09-05-2012, 07:13 PM
Correct. Better camber curve.
projectLS10
09-06-2012, 12:40 PM
Subbedddddd!!!! peicing together a 5.3 swap for my 2000 S10 Xtreme will def keep checking yours
01WS6/tamu
09-06-2012, 07:31 PM
Where did you get the control arms from?
zdiesel
09-06-2012, 10:11 PM
Right from UMI Performances website
http://www.umiperformance.com/
Freeman83
09-06-2012, 10:16 PM
nice! im planning on running the same control arm setup. cant wait to see how they perform on your truck
UMI Performance
09-07-2012, 10:00 AM
Awesome project, I am glad I found this thread... I am subscribing to see the progress. Thanks for the order as well!
Ryan
TypeSL2
09-07-2012, 12:04 PM
Sounds awesome man. Glad to see this thing is already up and running. Definitely looking forward to seeing some real pics and vids.
James
zdiesel
09-07-2012, 12:27 PM
Thanks! If I'm impressed with these uppers you can expect another order from me in the future for a set of tubular lowers and coil overs.
01WS6/tamu
09-07-2012, 11:43 PM
Well I was ready to order some upper control arms and a customer saw me driving it today. He had a million questions then finally asked if it was for sale told him 10,500 cash and he didn't blink a eye said to save it and he'll bring cash monday. Guess we will see. I really don't wanna let it go but wife n I want to buy a house so can't so no either because if I get in a spot and need to sell it I'll take a beating..:(:cry:
Tuckin15s
09-08-2012, 03:30 PM
Lol thats very rare someone actually asks and buys...
zdiesel
09-22-2012, 11:03 PM
UMI uppers with tall ball joints...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-09-22_09-15-25_169_zps2aacab1b.jpg
How everything sits right now...
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-09-22_09-15-38_873_zpsf4e41650.jpg
I thought I had more pictures of progress but I don't. Been dealing with a lot of small time consuming stuff, re-routing a brake line, figuring out hoses, wiring, etc... Still need to figure out what to do about the steering shaft issue. Possibly going to switch to a different radiator setup, should be going to the alignment shop in a couple weeks and be back up and running. Headers came off to put the tubular uppers on and to work on the brake line. Went to the junkyard and had a successful day, got a center console, some hood bolts (dropped one into the abyss of my truck), a 4.3 alternator to help clear the hood and some other small stuff. Test fitted the console, going to machine a bracket back up at school to located the shifter slightly forward and 2 inches higher.
http://i1185.photobucket.com/albums/z343/zdiesel123/2012-09-22_17-18-32_502_zps9846f9de.jpg
Will try and grab more pics tomorrow before I head back.
89gearhead
09-24-2012, 09:17 PM
nice build
v8sten
09-24-2012, 10:12 PM
I put those on my s10 along with the UMI lowers and QA1 coil overs. by far the best thing i ever done to my s10.
zdiesel
09-25-2012, 05:20 PM
UMI Lowers and QA1's will be the next step in my suspension build. Won't be until next summer though, then I'll have to do something with the rear end and suspension setup, then run something like a blazer tank or fuel cell in the rear for weight distribution. Hopefully I can get all that and a cam swap done next summer.
zdiesel
12-04-2012, 08:17 PM
I haven't forgotten about this!
Haha, progress has been just about zero though. Been so busy now that I'm back up at school and on the swim team, traveling most weekends for meets so not able to make it home. And no money to buy parts :(
Anyways, was home for a few days for thanksgiving break and tinkered a little bit. Trying to figure out best way to work through some problems. I think I'm going to need to run a different radiator, that or find a smaller condensor that can fit in front of the core support and between the hood latch assembly. Has multiple issues, from hose routing, to interfering with intake routing, etc...
I think either way, the truck pump has got to go. Looking at switching to an LS2 style water pump with some spacers to get proper alignment. Next issue is the radiator, I may cut the filler neck on it and move it closer to the core support so it won't interfere with intake routing as much. May consider switching to a thinner radiator, this one is overkill for this engine anyways. Maybe a stock S10 4.3 radiator recessed and pick up a new core support from the junkyard to modify? Or a griffin perhaps? I want it to fit pretty flush with the condensor in front of it, so needs to be small. Would like to hear some peoples thoughts on these issues.
Some pics for your time and consideration.
http://i1185.photobucket.com/albums/z343/zdiesel123/8A95E3FD-E9B0-4A9B-9426-02BD8ED5074E-5859-000005F3E2339818.jpg
Radiator isn't in on that picture...
http://i1185.photobucket.com/albums/z343/zdiesel123/803B9188-9BB3-4F04-AE0B-2D28251B8734-5859-000005F3DFE24A07.jpg
How it's sitting right now, needed to roll it out of the shop so my dad could use it while I'm up at school.
http://i1185.photobucket.com/albums/z343/zdiesel123/A8DB683D-4E3F-4F27-A9C1-8A4DB67A5452-5859-000005F3DC1BE606.jpg
Parts bin! haha You can see the radiator in this pic, and how far out the filler neck sticks out.
Picture for reference so you can see how far this radiator sticks out with the condensor in front of it.
lsxtreme17268
12-17-2012, 06:42 PM
nice build you have going on . Why not recess the radiator and use the CPW condenser in front of the core support ? Or one the same size for cheaper of ebay or something lol
2lazy4agoodname
12-17-2012, 08:54 PM
Awesome build! Cant wait to see the finished results
Stormed_Norm
01-03-2013, 10:43 PM
Nice build. What are the throttle and cruise cables from? Are they all stock 4.3 cables or ???
zdiesel
01-04-2013, 02:04 PM
Correct. Stock 4.3 cables, the bracket on the intake needs to be adjusted a little bit because just hooking everything up it pulls the throttle open just a little bit, so I had to open up the mounting holes and slide the bracket further forward.
lsxtreme17268
01-04-2013, 02:12 PM
You could get a smaller condenser and recess your radiator. Would look much better IMO. Cpw sells a smaller condenser but probably fInd one cheaper with a little searching
zdiesel
01-05-2013, 08:10 PM
I haven't figured out what I'm doing yet with that situation. If I can find a deal on a CPW radiator and condensor setup I will do that. Otherwise I will just move the stock condensor in front of the core support and modify the hood latch assembly so it will fit, that way I can recess the radiator another 1.5" forward allowing more room for my intake routing.
Th original budget and time frame has just gone out the door with this truck. I'm going to buy another car this summer to daily drive and really do this build the way I want to. Which include a relocated fuel tank (blazer tank behind rear axle), longtube headers, built rear end, cam swap, maybe a different intake and some other odds and ends. May even just find a clean frame and have it stripped and painted.
zdiesel
02-27-2013, 07:59 PM
Back from the dead...big updates hopefully to come over the next 2.5 weeks, good pile of parts waiting for me to come home for spring break on Friday.
Here's how the truck has been sitting the past couple months, dormant.
http://i1185.photobucket.com/albums/z343/zdiesel123/45BDE8D5-F2FD-4E17-8D5E-59CA8E64BEA2-5521-0000053E03789E5A_zpsa2dddcfc.jpg
Here's a question for you LS gurus. When I ordered my harness and tune from Jared, I planned to run the original truck intake with the stock injectors. I picked up an LS intake complete with injectors and fuel rail that I plan to run now (yes my accessory drive is changing). My concern is with the injectors, I know I can buy adapter for my harness, but does the tune need to be changed for the new injectors?
FakeSnake
02-28-2013, 09:43 PM
just some food for thought... the explorer 8.8" axle from 4x4 is pretty beefy and will hold pretty much whatever you can throw at it... bolts right in... jeep grand cherokee shafts will clear the headers and bolt right up to the column and the gear box...
zdiesel
02-28-2013, 09:55 PM
I've got a cherokee shaft slipped in right now, need to tweak it a little bit for final fitment. I've read about the 8.8 axle swap, if anything what I'll probably end up doing is buying an 8.8 with 3.73 gear and the factory locker and get it narrowed and custom axles made with the correct bolt pattern for GM wheels. Having two different bolt patterns would annoy the living hell out of me haha
But for now, I've got an Auburn posi and an LPW girdle I'm going to throw on my stock rear and weld up the tubes to the pumpkin. It should be able to hold up fine to my little 5.3/T56 for a while, especially on street tires.
FakeSnake
02-28-2013, 10:08 PM
no need to narrow it at all...just have the axle flange redrilled to 5x4.75 and get some wheels with a 7" backspace
zdiesel
03-01-2013, 10:10 AM
I would get it narrowed to fit my factory wheels.
zdiesel
03-01-2013, 11:27 PM
Parts parts parts!!!
Complete LS6 intake manifold that I picked up local!
http://i1185.photobucket.com/albums/z343/zdiesel123/74BF2EA4-E309-45FE-8A60-4FF4E621B098-7651-000008158AC8678E_zpsbdfd965d.jpg
Fuel rail slightly bent, going to try and straighten it out...
http://i1185.photobucket.com/albums/z343/zdiesel123/C3126383-AC39-4924-9B3E-D3041C7A5059-7651-000008158618DFF4_zps79951a20.jpg
New S10Warehouse leaf shackles, old ones are rusting away!
http://i1185.photobucket.com/albums/z343/zdiesel123/6DBB6FC0-DEA7-4A75-941B-D3B27F0093FC-7651-0000081581CF5FD6_zpsbd845574.jpg
LSBrackets PS pump/alternator relocate bracket...
http://i1185.photobucket.com/albums/z343/zdiesel123/7A2F462B-E283-4D34-B755-2CFAD2574423-7651-000008157DCE0649_zpse60da6a0.jpg
New AC Delco L99 Water pump and tensioner
http://i1185.photobucket.com/albums/z343/zdiesel123/459CC31D-8E40-469B-9ACE-EF29233077F1-7651-0000081579570718_zpsf7c7e3ab.jpg
AC Delco reman PS pump for the new accessory drive setup...
http://i1185.photobucket.com/albums/z343/zdiesel123/B72AAE11-1249-4292-B9A5-EBFA14139FDE-7651-000008156FD85F3F_zps85162f63.jpg
And I picked up an Auburn posi out of an SLP Camaro to swap in my rear...
http://i1185.photobucket.com/albums/z343/zdiesel123/FDA9B3A5-B4B6-443E-AF3E-202CF2CA9FE2-7651-000008156AFEFE4B_zpsbebce895.jpg
Work starts tomorrow!
zdiesel
03-02-2013, 09:12 PM
After bleeding brakes in one car, changing oil in another, and changing tires and oil on another car, I finally got the truck into the shop!
http://i1185.photobucket.com/albums/z343/zdiesel123/897CAE04-5963-4AEF-B412-89F513DF55C3-8536-0000088AB718B251_zpsa9e9e0b9.jpg
Yeeeee...L99 pump fits nice, should make running hoses a ton better!
http://i1185.photobucket.com/albums/z343/zdiesel123/B0CDC93E-AD29-48E8-9615-2E1441D98075-8536-0000088522D7BDFF_zpscb802c7a.jpg
Few issues I did run into however with swapping the intake. First issue is the throttle cable bracket. Going to have to do something with this. Truck intake bracket on left, F-Body bracket on right.
http://i1185.photobucket.com/albums/z343/zdiesel123/B5A19ED0-B1D8-41A1-99C8-1B121A173B59-8536-0000088529982F1B_zps4943cdd5.jpg
And the Map sensor is different than the truck one, do people just chop the clips off on one side of the sensor and run it? Cause as of right now, that's what I'm planning to do.
http://i1185.photobucket.com/albums/z343/zdiesel123/537D9CEA-01DC-4DB0-B31D-6AED381595A8-8536-0000088526F00BA3_zps9ebddbf0.jpg
zdiesel
03-04-2013, 08:23 PM
Update. Worked on the truck a little bit more today. Here's my bracket from LSBrackets, I took it to a friends house and sand blasted it and cleared it. Looks tons better than the aluminum stock finish it comes with.
http://i1185.photobucket.com/albums/z343/zdiesel123/24376FB1-D58B-41FC-BE3D-DA9C181E0D93-9914-0000092B54D42D82_zps84d37564.jpg
Fitted on the motor...
http://i1185.photobucket.com/albums/z343/zdiesel123/3A5C0411-3BDD-40A0-BD15-B43B5436DA61-9914-0000092B497F4D5E_zps10242c74.jpg
Recessed the radiator all the way forward. Going to modify my hood latch mechanism and fit the stock condenser in front of the core support.
http://i1185.photobucket.com/albums/z343/zdiesel123/9402B680-0B5B-4DE5-B4B6-C5EED0EFF563-9914-0000092AE0468739_zps11b60f60.jpg
Test fitting an intake tube, I think this is how it's going to be run.
http://i1185.photobucket.com/albums/z343/zdiesel123/AE126846-F216-4F71-A2C8-FE5178A5AC48-9914-0000092AFA282A7F_zpsd0389570.jpg
Fuel rail and some EV1 pigtails are on the way. Going to pick up PS pump pulley, an idler pulley and radiator hoses tomorrow.
zdiesel
03-06-2013, 10:14 PM
Picking away at small stuff, trucks starting to come together. Relocated my electric fans, got my radiator hoses in, started pulling my harness apart to swap the EV1 pig tails on as soon as they come in.
Lower rad hose.
http://i1185.photobucket.com/albums/z343/zdiesel123/D9862C43-DD03-4652-878E-5E32D1BBAAC5-1008-00000066DE7BFAC0_zpsf6fce593.jpg
Upper rad hose, after trying 7 different belts, I found one that fit haha
http://i1185.photobucket.com/albums/z343/zdiesel123/BB2DD9E2-9397-456F-8DBD-5BDF2195241C-1008-00000066E2EF5625_zps9d90d984.jpg
zdiesel
03-07-2013, 08:17 PM
Got some parts on the way, shorter K&N filter for my air intake setup, some fittings and power steering hose to make a new high pressure line that will fit better than the factory one I have on their that's like 2 miles too long haha.
Got a bouquet of EV1 connectors from the USPS man!
http://i1185.photobucket.com/albums/z343/zdiesel123/6BA01C1C-B492-4417-85A0-CA34E05AC4C6-1008-000000AE48F3209C_zps0b356f13.jpg
Set to work swapping the old mini delphi style connectors over to the EV1 connectors fro the LS6 injectors...
http://i1185.photobucket.com/albums/z343/zdiesel123/90F81F3B-7CCF-4DFA-9231-1A78582B78CE-1008-000000AE4C6995E7_zps483d2eca.jpg
Dat soldering.
http://i1185.photobucket.com/albums/z343/zdiesel123/67293083-7DDA-45B2-807E-16E9A72B25E0-1008-000000AE4F35AAFF_zps65e49ad4.jpg
One side all finished and taped back up!
http://i1185.photobucket.com/albums/z343/zdiesel123/268DFFEB-54D7-43F1-BAE0-584A07356759-1008-000000AE52FAA81C_zps5028259c.jpg
LS6 intake makes this thing look 10x better under the hood, so glad I switched haha
http://i1185.photobucket.com/albums/z343/zdiesel123/8412FAFE-4592-4A78-8C7A-C77D4A3B8092-1008-000000AE572DF2C0_zps688a1d36.jpg
bonecrrusher
03-08-2013, 12:33 PM
Excellent use of a mouse trap - I need to remember that one.
zdiesel
03-08-2013, 01:28 PM
Makes soldering 10x easier haha
zdiesel
03-10-2013, 12:22 AM
Picked a dial indicator off ebay to setup my rear diff...
http://i1185.photobucket.com/albums/z343/zdiesel123/6C32222D-F0F0-4D20-BF5A-2B3199D54CD8-3881-0000016CEDFFFEA1_zps859c25ae.jpg
FINALLY figured out my steering shaft situation haha, went to the junkyard today and got some miscellaneous stuff for the truck and pulled a shaft from a cherokee, was much longer than the other jeep shaft I had. Brought it home...did some thinking about my steering shaft and came up with this design...
I cut down the jeep shaft to the length I needed, and then took the 1" DD shaft from the stock S10 steering shaft and welded it to the jeep shaft. With how it's setup, it has a few inches to collapse given an accident and is also easy to install and remove.
Cut and marked...
http://i1185.photobucket.com/albums/z343/zdiesel123/0B37569C-2EF9-4470-9742-2E470BB9A9FF-3881-0000016CEA26C5F5_zpsf266e3af.jpg
Ready for welding, drilled a couple holes for welds for more strength...
http://i1185.photobucket.com/albums/z343/zdiesel123/1A61984F-11E7-4422-988C-A950E7724B62-3881-0000016CE553FF57_zps6dfeeacd.jpg
All welded up...
http://i1185.photobucket.com/albums/z343/zdiesel123/7A925E8F-305E-46EC-B809-A89375E09F12-3881-0000016CE1DA0E41_zps87e09d11.jpg
Painted it up...
http://i1185.photobucket.com/albums/z343/zdiesel123/37BB6604-C930-466A-887D-01923A7EFC72-3881-0000016CDD9AC14C_zps88bcc22d.jpg
And clearance on the truck...may not look like much but it's better than what I started with! I'm comfortable with it! I'm going to shim the steering box some to get a little more angle out of it as well.
http://i1185.photobucket.com/albums/z343/zdiesel123/4442EACE-584C-497C-8D8B-B92258C76FD1-3881-0000016CD516D8DB_zpsd31cc772.jpg
Started to work on relocating the AC condenser and modifying the hood latch.
http://i1185.photobucket.com/albums/z343/zdiesel123/E1497D88-D252-4C72-B7BF-E596E72052A7-3881-0000016CD0B4AD79_zps0f2d2034.jpg
How I mounted it, there's foam on the back side between the core support and condenser. Can also see the cut I had to make for the lines to travel through the core support.
http://i1185.photobucket.com/albums/z343/zdiesel123/A98B8E41-87C0-443E-B697-46B1F46A73B1-3881-0000016CD9339CBE_zpsb2341c3c.jpg
zdiesel
03-10-2013, 08:54 PM
Finished up the hood latch today. Picked up some 2" steel c-channel from home depot. Did some pie cuts to get my bends...
http://i1185.photobucket.com/albums/z343/zdiesel123/2F4A6BB6-AB3C-4C0C-B816-71AB630B0157-4356-0000019F89EEC8F2_zpsf80f9987.jpg
Welded up the pie cuts and working on smoothing welds out...
http://i1185.photobucket.com/albums/z343/zdiesel123/9E94B4AF-1266-4AC4-A3B5-8BEBD7611EA4-4356-0000019F8CC91BFB_zps4f7e5fd0.jpg
welded a piece of the c-channel on top of of itself where it mounts to the core support on the bottom. Some stitches in the corner where they were pie cut for strength.
http://i1185.photobucket.com/albums/z343/zdiesel123/527E4E0D-6855-4BD7-8995-6B4B1B87F7AF-4356-0000019F7C19DCC1_zpscfd17e14.jpg
Was pretty happy with these welds...not the ones on the inside haha
http://i1185.photobucket.com/albums/z343/zdiesel123/33F359BC-1E10-40DB-AF9A-68863F86038A-4356-0000019F80687346_zpsaa6a00f5.jpg
Mocked up...
http://i1185.photobucket.com/albums/z343/zdiesel123/D0B9F986-B123-47D3-8ADD-8279364F32DF-4356-0000019F8456973B_zps3aab432a.jpg
And all painted up with the condenser mounted up! Had to tweak the power steering cooler lines a bit, came out pretty good though!
http://i1185.photobucket.com/albums/z343/zdiesel123/63A0EBFB-F07A-43DB-A847-F9273C127E1F-4356-0000019F91452D83_zpsc7cfc1c5.jpg
http://i1185.photobucket.com/albums/z343/zdiesel123/E2F458FE-775D-40C4-9E11-BBDB82958754-4356-0000019F77F7AEAE_zps2da2aea9.jpg
Kory 88Iroc Lt1
03-10-2013, 10:26 PM
Nice work. The finished product looks factory.
Kory
cprmn14
03-11-2013, 08:22 AM
Looks good, welds look much better lol
zdiesel
03-11-2013, 11:29 PM
Thanks!
Not much progress today. Some parts came in, hose, adapters and fittings for my new power steering line (still waiting on one fitting that got drop shipped) and a shorter K&N filter for my air intake.
http://i1185.photobucket.com/albums/z343/zdiesel123/715E9EEF-58A9-40C9-9982-7CE7F42F4095-5173-0000020DDA15479F_zps2016242b.jpg
Got the new fuel rail in...
http://i1185.photobucket.com/albums/z343/zdiesel123/5CF62D70-128E-440D-A698-3406D9127211-5173-0000020DDDCCE748_zpsfecabaf6.jpg
Going to look at some wheels tomorrow...
http://i1185.photobucket.com/albums/z343/zdiesel123/8BA30862-0958-4836-83C4-9046CCA8CF8D-5173-0000020E25FB38A2_zpse12116d9.jpg
zdiesel
03-12-2013, 11:25 PM
I didn't get much done on the truck today, went back to school to use a mill for my shifter bracket, that didn't work out the I found out that guy sold those wheels to someone else when we scheduled a time to meet so I could check them out. So I was pretty pissed today, wasted the whole day.
I did get some plug wire sleeves in, though I had some pictures of them but apparently not. After getting home pissed I busted out the sawzall and started cutting that 3/8 plate to make my shifter bracket since I didn't get anything done at school.
http://i1185.photobucket.com/albums/z343/zdiesel123/DBB57EA3-3317-40E2-A421-4474758C7605-274-0000004C5C51FDA2_zpsa0395dbe.jpg
Picture makes it look really ugly, I'll get some better ones tomorrow when its installed. And then I got bored and fired it up for the hell of it!
http://i1185.photobucket.com/albums/z343/zdiesel123/th_5CF5E51B-E6A0-424B-8AF6-CE5A68FB6418-274-0000004C5F2FE874_zps2189bf77.jpg (http://i1185.photobucket.com/albums/z343/zdiesel123/5CF5E51B-E6A0-424B-8AF6-CE5A68FB6418-274-0000004C5F2FE874_zps2189bf77.mp4)
zdiesel
03-13-2013, 07:54 PM
Pictures of the plug wire sleeves I put on...
http://i1185.photobucket.com/albums/z343/zdiesel123/057B7ACA-CFA1-4F49-A141-A0B8A4351D5E-274-0000010AC1FC53EF_zpsc7c2c559.jpg
Swapped out my straight connector for a 45 on my fuel line for better fitment.
http://i1185.photobucket.com/albums/z343/zdiesel123/96B23D14-F237-4954-AD6A-9153CAD53226-274-0000010AB383DF23_zps9d31973c.jpg
Shifter bracket installed...
http://i1185.photobucket.com/albums/z343/zdiesel123/E53A43AE-0D45-46BF-BE35-BA3F70F5669B-274-0000010ABD84C680_zpsb49bc78c.jpg
New shifter height, it's so much better. Hand falls right onto the shift knob when your arm is on the arm rest.
http://i1185.photobucket.com/albums/z343/zdiesel123/1F938EBD-78F8-4D56-A4E8-8CA37F0AE4D5-274-0000010AB80E1323_zps27163aca.jpg
Fitted the headlights and grille back on, two wires, a power steering hose, my air intake, AC lines, and some miscellaneous hardware and it's all done under the hood!!!
http://i1185.photobucket.com/albums/z343/zdiesel123/A16D802F-B5E6-4418-8E77-BA3ED0927698-274-0000010AE7C752CA_zpsc8a406bb.jpg
Cool panorama shot!
http://i1185.photobucket.com/albums/z343/zdiesel123/19F40FDA-1527-46D8-8542-7939A27F2239-274-0000010AF07E04C5_zps06391873.jpg
zdiesel
03-14-2013, 05:18 PM
Does anyone know why there are two connections on the overflow tank? Obviously one is for the overflow from the radiator filler, but what would the second one be for?
http://i1185.photobucket.com/albums/z343/zdiesel123/c2e8d226-48a1-4901-bada-3fb0f92d1d60_zps6e173de7.jpg
Front fascia going back together, new GM bumper since the stock one had rotted away on one corner. Leaving it black for now until I can get it painted. Also new Anzo clear corners.
http://i1185.photobucket.com/albums/z343/zdiesel123/BBF32991-E8FB-435E-B9E9-8A62AE26D742-274-0000018CFE91690D_zpseeb917c5.jpg
zdiesel
03-15-2013, 12:14 AM
Buttoned up all of the wiring tonight, yay! Once my power steering line stuff, AC line parts, and air intake parts come in I'll just need to button those up and it will be all finished under the hood! Tomorrow, I'm going to pull it out (under it owns power!!!!! :D) and give it bath...it's dirty from sitting for close to a year haha
http://i1185.photobucket.com/albums/z343/zdiesel123/FB26CAE2-43E9-4E3C-8A3C-55FF48692530-274-000001A0D70BB00A_zps45f0a8dc.jpg
My spring break comes to an end soon so before I leave I'm going to pull it back out into the barn and drop the axle out from under the truck so I can work on that and the Nova can get some loving before summer too. Hopefully I will be able to come home next weekend though and button up the air intake, steering lines and all that stuff. Rear axle hopefully too, and then it just needs to go to a shop and get an exhaust, alignment, AC charge and sticker...
THERE'S LIGHT AT THE END OF THE TUNNEL!
1bigoldman
03-15-2013, 08:25 AM
The bottom connection goes to the radiator overflow. The top one is to route the tank overflow below the truck.
zdiesel
03-15-2013, 11:57 AM
Got it, thanks!
Just about a years worth of dust...
http://i1185.photobucket.com/albums/z343/zdiesel123/C71309F7-0AF9-424B-82E5-D2C52A667481-274-0000024B51603489_zpsf479cbb7.jpg
Cleaned up!
http://i1185.photobucket.com/albums/z343/zdiesel123/A6803AD5-9BC2-492B-A58A-94A637C9B535-274-0000024B626E5A5C_zpsd4dfaae3.jpg
http://i1185.photobucket.com/albums/z343/zdiesel123/A59CC792-7CF5-48D4-BE00-DFF3A806F3BA-274-0000024B6B18BC45_zps3fe88a77.jpg
zdiesel
03-16-2013, 01:10 AM
Threw the 3.73's from the stock diff onto my posi unit..
http://i1185.photobucket.com/albums/z343/zdiesel123/C4BE005A-84D2-492B-93AA-5F1781A8611D-2891-0000028D16B3D493_zpse2c2b263.jpg
Pulled the stock diff out of the rear...
http://i1185.photobucket.com/albums/z343/zdiesel123/2B3064E7-8242-41D0-8C87-C84C0F68D8BC-2891-0000028D13006085_zps8e58ac72.jpg
And now...
http://4.bp.blogspot.com/-OQZjuDH-Dco/T8FSmyJUG4I/AAAAAAAABQY/eK18Udm9cik/s1600/funny-dog-pictures-i-have-no-idea-what-im-doing.jpg
LOL, lots of youtube video's and reading right now. I'm so beyond lost haha
Z28-Vortec
03-16-2013, 01:27 AM
Okay, Mouse trap soldering is just epic, thank you for making soldering that much easier. Why don't they market mouse traps for this!
zdiesel
03-16-2013, 09:19 PM
They really should!
Posi installed, took some trial and error but I finally got it all figured out!
http://i1185.photobucket.com/albums/z343/zdiesel123/9860D5F2-5864-402D-82C5-87E90C62D689-3354-00000344411E7FD6_zps60e4f354.jpg
LPW girdle installed...
http://i1185.photobucket.com/albums/z343/zdiesel123/7E1FECD8-2BEC-4BD3-BF5F-5044FA54AEF3-3354-0000034448214B99_zps21f6ad34.jpg
For S10 guys concerned with swaybar clearance and looking for a girdle, this one has plenty of clearance!
http://i1185.photobucket.com/albums/z343/zdiesel123/C97DE0D1-7B76-4079-93B4-A6EB493A6193-3354-0000034438ECA9AF_zps39ccf7d2.jpg
Rear end all tied back together
http://i1185.photobucket.com/albums/z343/zdiesel123/9D953F11-31DF-4F2A-A55A-4F5787F53D9C-3354-000003443CFEB3B3_zps748ec616.jpg
Replaced the leaf shackles as well, they were due...one of them had a rust hole in it LOL
http://i1185.photobucket.com/albums/z343/zdiesel123/F160F7B7-72EE-4441-9D65-2CE1CD442939-3354-000003444F2DDA48_zps470d04c3.jpg
zdiesel
03-22-2013, 07:20 PM
Home for the weekend to do some more work on the truck! Parts in!
- 4" aluminum intake tube to finish my air intake
- 2.5" x-pipe
- Section of power steering hose
- black radiator hose fitting for my coolant crossover connection
- O2 bungs
- SS mirror glass, broke one pulling the truck out of the shop last weekend :rant:
- SCE copper collector gaskets
- Collector bolts with locking nuts
http://i1185.photobucket.com/albums/z343/zdiesel123/18B4F74B-CB48-48B0-B421-263CA6C08D0F-1420-000001AC74E1ABF9_zps3b22f500.jpg
Freakin knuckle heads at summit sent me two different collectors, they're both 2.5" pipe and have the same part number (probably mislabeled by some knuckle head), but one has a much thicker flange and larger bolts holes.
http://i1185.photobucket.com/albums/z343/zdiesel123/B1FCF17B-9C9E-403D-AFF7-7DE74F7C1316-1420-000001AC81265C25_zps1cd6da88.jpg
http://i1185.photobucket.com/albums/z343/zdiesel123/E0828DBB-8678-465E-A0B9-6B25F45591DF-1420-000001AC7A30B370_zpscc926250.jpg
zdiesel
03-23-2013, 01:07 AM
Oh! And a stang shift boot for my console...
http://i1185.photobucket.com/albums/z343/zdiesel123/631310A2-8B01-4AC2-9A67-C45BB09CF235-1420-000001C04EC5DCD5_zps1864c094.jpg
zdiesel
03-24-2013, 12:32 AM
More pics!
Power steering hose, its covered in wire loom now.
http://i1185.photobucket.com/albums/z343/zdiesel123/512A4B5C-A22D-4BAB-9794-550E1B8EFEF0-2113-0000021FD647AE55_zps34b1cbe3.jpg
The fittings used, 90 degree off the box and a straight fitting out the pump...
http://i1185.photobucket.com/albums/z343/zdiesel123/CACB5078-E8E4-4718-A032-A08597C45018-2113-0000021FD1FF83A4_zpsf942908e.jpg
Intake routing...
http://i1185.photobucket.com/albums/z343/zdiesel123/5E98F1F6-F0B8-418C-9866-7FDF0248EF00-2113-0000021FDF1E21D9_zpsd159d768.jpg
Built a small box out of one of the metal panels that came with the silverado cold air intake kit I bought to use for parts, fit pretty well. Bolted it to the core support and then used a piece of carbon fiber I had laying around for the bottom panel. When I get some more time, I'll make it a little more air tight. For now it serves the purpose of making sure it doesn't suck up a bunch of water LOL
http://i1185.photobucket.com/albums/z343/zdiesel123/3838FD6F-7BF9-44E6-8901-BE65BFBCD0C6-2113-0000021FCDCAE494_zpsf4961836.jpg
Intake tube painted black and all installed...
http://i1185.photobucket.com/albums/z343/zdiesel123/659D8D15-663E-4AB7-A88F-8949BBFD7546-2113-0000021FC0620285_zpscb240665.jpg
Made a bracket for my console, didn't get a picture of that. But my next big piece I'm trying to work on is the shift boot...How have other people installed their shift boots? I'm trying to figure out how to do it correctly and make it look clean. I thought of attaching it from the bottom of the console, but there isn't much to attach it to, and I could attach it to the top of the console (honestly doesn't look that bad), but I'm not real crazy about that either. I'm debating bringing the console to an upholsterer and just letting them do it...here's some pics of the boot just laying on top of the console.
http://i1185.photobucket.com/albums/z343/zdiesel123/527BBF25-B03B-4D11-AFF0-3B322B284CD0-2113-0000021FC52D5B89_zps294bf733.jpg
http://i1185.photobucket.com/albums/z343/zdiesel123/6681E116-A5D4-48FB-B2AB-30F705E89713-2113-0000021FC98B6915_zps06f598d3.jpg
Tuckin15s
03-24-2013, 12:48 AM
Love the intake setup looks great, also the shifter boot looks great too!
Agree intake looks good and think if you took your plastic radiator shroud to a machine shop and had them bend up something out of alum and polished it up itd look great. Nice swap but you cant wait to enjoy it
Which p/s pump is required for that accessory bracket, and whats the part # on your shifter boot?
That bracket looks a lot cleaner then the truck one
zdiesel
03-24-2013, 08:17 PM
Thanks guys! I agree, I think the LS6 intake is so much better than the truck intake, can't wait to get some vette rail covers on their! Then it will look real clean!
Here's the link to the shift boot, I got it for like $40 on ebay. It's really nice, real leather. Matches the stock interior color pretty well...
http://www.drakeautomotivegroup.com/Store/Product/E7ZZ-7277-A.aspx?wid=141
The bracket uses a pump from an 88-89 chevy pickup and uses the stock LS power steering pulley, AC Delco PN 36-517091
Here's the little bracket I made for the center console...
http://i1185.photobucket.com/albums/z343/zdiesel123/15C4A076-445C-408F-80AD-AF6467D7E31A-2113-0000026E7C00A30C_zps3f673c8e.jpg
Here's how I have the shift boot secured for now...
http://i1185.photobucket.com/albums/z343/zdiesel123/F72A3735-B29C-4DF0-9D5E-8FD23CCCDCD2-2113-0000026E7FD2D213_zpsdf188510.jpg
I want to find some flexible edge trim to wrap around the edge of the boot and cover up the screws like this...
http://www.trimlok.com/secure/Content/ImagesProducts/cf0c2ad9-4cde-4ea9-a284-501eaa904986.jpg
zdiesel
03-24-2013, 08:25 PM
Oh, and I almost forgot. It's off to the exhaust shop next weekend and then it just needs to be registered!!!!
zdiesel
03-30-2013, 12:15 PM
Power steering fluid is a little low in the video, hence the power steering pump whining. Does it really need an exhaust system?
http://i1185.photobucket.com/albums/z343/zdiesel123/th_FDC593EA-9456-41BA-A712-1DA0BC75E322-7786-000008FFE333C11F_zpsfed138ac.jpg (http://i1185.photobucket.com/albums/z343/zdiesel123/FDC593EA-9456-41BA-A712-1DA0BC75E322-7786-000008FFE333C11F_zpsfed138ac.mp4)
Big red and little red! Off to the exhaust shop she goes!
http://i1185.photobucket.com/albums/z343/zdiesel123/CD4F0912-908A-473D-AA42-C4A6E950CAD9-7786-000009005B151CE6_zps6c60a1e0.jpg
zdiesel
04-11-2013, 07:27 PM
Some photos from the exhaust shop, should be done soon.
http://i1185.photobucket.com/albums/z343/zdiesel123/CC41ECD1-E7DF-46B5-BAD7-7282CC26DF08-9867-00000A1AC2E89A5D_zpsd810dddb.jpg (http://s1185.photobucket.com/user/zdiesel123/media/CC41ECD1-E7DF-46B5-BAD7-7282CC26DF08-9867-00000A1AC2E89A5D_zpsd810dddb.jpg.html)
http://i1185.photobucket.com/albums/z343/zdiesel123/173D04C9-BCBA-408E-8171-35DD27C0203E-9867-00000A1ACAC1B32A_zpsba452ac0.jpg (http://s1185.photobucket.com/user/zdiesel123/media/173D04C9-BCBA-408E-8171-35DD27C0203E-9867-00000A1ACAC1B32A_zpsba452ac0.jpg.html)
http://i1185.photobucket.com/albums/z343/zdiesel123/B56BA855-12E4-4C69-8F6F-EDB963EB77CE-9867-00000A1ACD44DED1_zpsa98f59a6.jpg (http://s1185.photobucket.com/user/zdiesel123/media/B56BA855-12E4-4C69-8F6F-EDB963EB77CE-9867-00000A1ACD44DED1_zpsa98f59a6.jpg.html)
zdiesel
04-13-2013, 03:33 PM
AC parts...ran $58 shipped for everything.
http://i1185.photobucket.com/albums/z343/zdiesel123/AA818608-A1F0-48C5-93CF-CEEB2679E03A-945-0000006218204AB9_zps732930f0.jpg (http://s1185.photobucket.com/user/zdiesel123/media/AA818608-A1F0-48C5-93CF-CEEB2679E03A-945-0000006218204AB9_zps732930f0.jpg.html)
zdiesel
04-14-2013, 10:16 PM
Oops...
http://i1185.photobucket.com/albums/z343/zdiesel123/7ED336F1-94B2-49AA-9386-D5AE78A3669B-2193-0000010F1AB88F9A_zps3ed93f21.jpg (http://s1185.photobucket.com/user/zdiesel123/media/7ED336F1-94B2-49AA-9386-D5AE78A3669B-2193-0000010F1AB88F9A_zps3ed93f21.jpg.html)
Bought a set of brand new take off C6 wheels. 18x8.5 front and 19x10 rear. My ABS is still setup, will I have any issues running the staggered wheels with the stock corvette tire sizes (245/40/18 and 285/35/19)?
zdiesel
04-20-2013, 11:51 PM
Back on the road...air damn is actually on it now and I had to put the stock spindles back on for now as well, had some rubbing issues I didn't feel like dealing with at the moment.
http://i1185.photobucket.com/albums/z343/zdiesel123/61583B59-59ED-43D5-9741-812210013A70-3390-000002FADFAF8770_zps7865acb2.jpg (http://s1185.photobucket.com/user/zdiesel123/media/61583B59-59ED-43D5-9741-812210013A70-3390-000002FADFAF8770_zps7865acb2.jpg.html)
Didn't get many pictures of the exhaust but here are some. Came out nice.
http://i1185.photobucket.com/albums/z343/zdiesel123/9CA62AC2-5A1D-4423-A535-C01A9B447967-3390-000002FAE1F62341_zps7ad8255e.jpg (http://s1185.photobucket.com/user/zdiesel123/media/9CA62AC2-5A1D-4423-A535-C01A9B447967-3390-000002FAE1F62341_zps7ad8255e.jpg.html)
http://i1185.photobucket.com/albums/z343/zdiesel123/AF0758C3-DBDD-4EB9-9787-5FC0A19147B6-3390-000002FAE40600D8_zps28255425.jpg (http://s1185.photobucket.com/user/zdiesel123/media/AF0758C3-DBDD-4EB9-9787-5FC0A19147B6-3390-000002FAE40600D8_zps28255425.jpg.html)
And my dad giving it a quick rip haha
http://i1185.photobucket.com/albums/z343/zdiesel123/th_9F1AFC5F-00F3-495B-8CE6-F7660FD69B31-3390-000002FAE691F202_zps67a92523.jpg (http://i1185.photobucket.com/albums/z343/zdiesel123/9F1AFC5F-00F3-495B-8CE6-F7660FD69B31-3390-000002FAE691F202_zps67a92523.mp4)
Drove it up to school tonight. Got 24mpg at 75mph with a few hard throttle hits, I think it will improve a lot with a good tune.
zdiesel
05-04-2013, 11:05 PM
Small update of sorts. Installed my AC lines and blocks...
http://i1185.photobucket.com/albums/z343/zdiesel123/null_zps4e5633fb.jpg (http://s1185.photobucket.com/user/zdiesel123/media/null_zps4e5633fb.jpg.html)
http://i1185.photobucket.com/albums/z343/zdiesel123/null_zps40a8e2a8.jpg (http://s1185.photobucket.com/user/zdiesel123/media/null_zps40a8e2a8.jpg.html)
http://i1185.photobucket.com/albums/z343/zdiesel123/null_zpsc9d8daed.jpg (http://s1185.photobucket.com/user/zdiesel123/media/null_zpsc9d8daed.jpg.html)
Just need to get the AC charged now. Also popped my corvette rail covers on...
http://i1185.photobucket.com/albums/z343/zdiesel123/null_zpsec78feba.jpg (http://s1185.photobucket.com/user/zdiesel123/media/null_zpsec78feba.jpg.html)
http://i1185.photobucket.com/albums/z343/zdiesel123/null_zpsf697cd99.jpg (http://s1185.photobucket.com/user/zdiesel123/media/null_zpsf697cd99.jpg.html)
Kory 88Iroc Lt1
05-04-2013, 11:21 PM
What did you use for a driveshaft? Do you know the lenght off hand? I need to have one made.
have you checked the mileage any more? I'd be happy with my truck if it can pull 24mpg when its finished.
Nice build,
Kory
zdiesel
05-05-2013, 11:07 AM
I haven't. I need to top it off, drove it up to school doing 70 last night. I'll be interested to see what I get from that. From the gas gauge it looked about the same, we'll see. For the drive shaft I had the stock one cut down, I don't remember what the length was. I think it's written down on the receipt from the drive shaft shop, when I head home next weekend I'll dig through my receipts and see if I can find the length for you. If I were you I would just measure it yourself though.
loweredd
05-05-2013, 06:42 PM
I've got to hand it to you.....you DID invent a better mousetrap. I am going to have to try that little trick. I usually crimp and then solder, but that is pretty slick.
If you had to do it all over again, would you notch for the A/C compressor? I was thinking of doing the same thing on a Caprice wagon. Just notching a bunch out for the truck compressor, and not spending a bunch on relocation brackets.
zdiesel
05-06-2013, 09:37 AM
If I did it again, I would do vette accessories and use one of the Holley Cast AC compressor brackets that relocates the compressor up on the passenger side cylinder head. Would give it a factory look and require one less notch. And I wouldn't of had to modify my idler arm which would have been another bonus. I would like to find another frame and get it blasted and powder coated and setup everything as stated above. I'll probably get into another project before that happens though, who knows.
zdiesel
05-13-2013, 10:55 PM
Cracked a brake line, had to tow the truck home from school...
http://i1185.photobucket.com/albums/z343/zdiesel123/null_zpsd07b3d02.jpg (http://s1185.photobucket.com/user/zdiesel123/media/null_zpsd07b3d02.jpg.html)
With the help of my dad we fixed the rear brake line and threw new wheel cylinders and shoes on the rear. Brakes are all bled and good to go for a test drive tomorrow so I can see how these work...
http://i1185.photobucket.com/albums/z343/zdiesel123/null_zps1deea019.jpg (http://s1185.photobucket.com/user/zdiesel123/media/null_zps1deea019.jpg.html)
Made some leaf spring clamps to try and remedy my wheel hop on the cheap until I can pick up some caltracs.
http://i1185.photobucket.com/albums/z343/zdiesel123/null_zps80f95bdb.jpg (http://s1185.photobucket.com/user/zdiesel123/media/null_zps80f95bdb.jpg.html)
I've heard stories of people having good luck with these and some not. For $15 and about an hour of my time, I figured I would give it a try. I've got some 1" blocks coming as well to get the stance right.
