Forced Induction - turbo ltx guys-how r u standing up your
Boosted Firehawk
04-29-2012, 01:28 PM
stock radiator? or r using a aftermarket one?
what fans are u using?
I have a front mount and wanna know how everyone is doing this?
pix will be greatly appreciated
forgedlt4
04-29-2012, 03:48 PM
i removed my upper and lower core support. my griffin radiator "hangs" in the space.
http://i2.photobucket.com/albums/y29/96lt4/sgdfhsdfgs/272065b6.jpg
this cover, hides the radiator
http://i2.photobucket.com/albums/y29/96lt4/sgdfhsdfgs/0890bbc8.jpg
since I couldnt fill the radiator with that cover on there, this fill/overflow container was made
http://i2.photobucket.com/albums/y29/96lt4/sgdfhsdfgs/b8461c6f.jpg
forgedlt4
04-29-2012, 03:49 PM
Also, I am using two 1000 CFM pusher fans in front of the radiator.
PewterZCar
04-29-2012, 04:30 PM
derail has fans that push 2200cfm each. I run two of those. they cost 125 each
tt383lt1
04-29-2012, 04:43 PM
i use the stock fans and a huge aftermarket griffin radiator
Boosted Firehawk
04-29-2012, 05:01 PM
holy racecar. ya i dont wanna get that into it if i dont havr to. but that looks badass
tt383lt1
04-29-2012, 05:09 PM
i would mount the turbo and try to get the stock raditor in there. if al else fails you have to buy a aftermarket shorter one and puit it vertical. and i would try to use the stock fans. i found a site that did a flow test on the stock fans and they pull 9500cfm. i used two 2500cfm fand and they didnt cool it so i put two more and still wouldnt cool i stuck the stock ones on and stays at 185 all day
forgedlt4
04-29-2012, 05:13 PM
9500 CFM........ doubt it.
I am running two pusher 1000 cfm fans, and it cools fine.....
tt383lt1
04-29-2012, 05:26 PM
http://www.yellowbullet.com/forum/showthread.php?t=350404
here is the site. and how thin of raditor are you running? i have dual 1.5 griffin
forgedlt4
04-29-2012, 05:38 PM
Wow, i would have never thought that. if that guys testing is correct, I stand corrected, and i give my apologies.
Boosted Firehawk
04-29-2012, 07:14 PM
holy shit 9500 rpm for flow on a stock fan setup. THat is insane and I wonder if that is really true
Boosted Firehawk
04-30-2012, 09:27 AM
is there any other way to stand up the radiator and make everything look good?
tt383lt1
04-30-2012, 12:46 PM
some people cut the lower radiator support out 100% and then they cut the bottom of the top out so the radiator sits right below it. then they cut a hole for the raditor cap. it looks clean but harder to do.
Boosted Firehawk
05-03-2012, 04:55 PM
Anyone else have pix?
LT1 POWR
05-03-2012, 11:29 PM
Here is mine.
http://i61.photobucket.com/albums/h77/LT1_POWR/Camaro%20turbo%20build/DSC00107.jpg
Boosted Firehawk
05-04-2012, 12:02 AM
Do u have bigger and better pix of yours?
LT1 POWR
05-04-2012, 01:03 AM
I'm running a bigger than stock 600hp Griffin radiator and Flex-a-lite 420 dual puller fans. I think I'm going to switch the fans out for something better though. Problem is very limited space due to compressor housing. Don't really have any more pics of what I did to accommodate the larger radiator.
http://i61.photobucket.com/albums/h77/LT1_POWR/Camaro%20turbo%20build/DSC00112.jpg
Boosted Firehawk
05-06-2012, 04:42 PM
anyone else
Boosted Firehawk
05-09-2012, 06:33 PM
anyone else?
Also what fans are recommended
