96z28_lt1
04-30-2012, 09:37 PM
LT1 i finished and put back together, the car had a no start problem that was me adjusting my valves to tight, re adjust got it to start with WOT. The vehicle reved freely but as soon as i let off the throttle it died. I figured since i got it to start it probably died do to the sensors all not being hooked up so i threw it all back together. Go for a start and it reved freeley again but did not idle stil let off throttle and bam died. Got out of the car looked the engine over and such and was puzzled went to try a start again and this is what i got
http://www.youtube.com/watch?v=Y6GCiZXTgIo
that was all with WOT, anyways i tinkered with it some more and readjusted valves changed out the bigger fuel injectors i put on the car, since the computer still isn't tuned for the mods. Fired the car up after adjusting lifters again under WOT it starts revs a bit but not freely kind of chose were it wanted to rev to capping at like 4500 rpms knew this wasn't right so i let off the throttle and it stalled out like usual, looked stuff over and am just down right confused, try to start it again WOT and it starts holding throttle down it revs to like 700rpms and then a second later up to 1500 and held it there. Still confused get out check spark plugs wires firing order on opti and just sit there with no idea. Now it only somewhat starts with the throttle 1/4 to 1/2 way down depends and then i'm lucky if i can keep it alive at 500rpms
car is a 96 with the m6
The new build is
LE2 heads with patriot extreme gold springs
comp cams xfi280 230/236 113lsa
pacesetter longtube headers with ORY
ported lt1 intake
professional products 58mm throttle body
scorpion 1.6 nsa rr
trickflow chromoly pushrods
guide plates
took off air pump, a/c system except the box in the firewall, evap system, egr and replaced the traction control module on the valve cover with a non traction control throttle cable
new aluminum intake elbow
replaced water pump
opti
fuel filter
fuel pump
new wires
spark plugs
sensor in waterpump
coolant sensor in the head
oil level sensor
oil pressure sensor
I know i have spark
I know i have fuel not sure if its enough though could be bad pump even though its new gonna get a fuel pressure test tomorrow
Gonna get a compression tester tomorrrow to make sure i have that also
just curious on what everyone else thinks like i said it doesn't even start under WOT anymore and i need to feather the throttle about 1/4 to 1/2 way to get it to start, if compression is good again tomorrow i guess i'm gonna rip down the front and check the new opti because at this point the only think new on it is the back housing.....thats another story though
The new build is
ported lt1 intake
scorpion 1.6 nsa rr
guide plates
replaced water pump
opti
fuel filter
fuel pump
new wires
spark plugs
sensor in waterpump
oil level sensor
oil pressure sensor
I know i have spark
