Which cam for 370 ci?
Old 03-27-2004, 06:37 PM
Okie02's Avatar
Default Which cam for 370 ci?
well im buildin a 6.0 for my truck...i got a 224 .581 cam for it but i think i wanna go bigger, like maybe a 228 .588 or the texas speed 231/237...i dont wanna go to big cause i need some good low end torque to get my heavy *** truck movin...what do u guys think i should go with? thanks
Old 03-27-2004, 06:42 PM
Slowverado's Avatar
TREX....the TSP cam you listed makes good power too.
Old 03-27-2004, 09:55 PM
Okie02's Avatar
yea i wish...but thats just a little to big...would the 231/237 cam work well with the PPls6 stage 2 heads? would the valvesprings hold up ok? thanks!
Old 03-27-2004, 10:22 PM
DenzSS's Avatar
It is a truck. Regardless of anything else, you have a lot of weight to get off the line. In short, you need torque to overcome the mass of the vehicle and accelerate it off the line. I'd stick with the 216/220 you have or have some real custom work done by a pro.
Old 03-27-2004, 10:36 PM
Slowverado's Avatar
216/220 doesn't make torque in a 5.3, what makes you think it would in a 370? the added cubic inches of your new motor will help a TON, and the TSP cam will be fine with the PP heads you have, PP and TSP work together so they would know 100%.
Old 03-27-2004, 10:40 PM
DenzSS's Avatar
Doh, I missed the 370 part.
The TSP is still too large of a cam for the 370 unless he is going to run a lot of compression. Even then, the loads of a truck are going to put some danger of detonation into the mix.
Old 03-27-2004, 10:56 PM
Okie02's Avatar
really? i see people putting bigger cams in the 346ci.
Old 03-27-2004, 11:20 PM
DenzSS's Avatar
It all depends on what you're doing. A truck weighs a hell of a lot more than a F-body or Vette. It is up to you, of course.
IMO, no way in hell would I put a cam that size in a truck. I'm sure you'll get better dyno numbers with a big cam, but I'll wager you'll run a faster 1/4 if you maximize your torque throughout the entire curve. It is't my truck, though.
Old 03-27-2004, 11:29 PM
Okie02's Avatar
ok man thanks for the input...i need some other suggestion though guys...
Old 03-27-2004, 11:35 PM
Slowverado's Avatar
the TSP cam will perform GREAT in the truck...i had the 222/226 .569/.573 112 in my 5.3 and it ran great, the low end wasn't as good as with my other cam, but it was still acceptable...and it was plenty to drag a few f-bodies outta the hole...
Old 03-27-2004, 11:39 PM
Okie02's Avatar
are u sayin the 228 or the 231/237 cam will be good? or both?
Old 03-27-2004, 11:46 PM
Slowverado's Avatar
either...i would go with the TSP cam personally due to it's friendliness to nitrous oxide...you know i like nitrous...and it looks like you hae it in mind also.
Old 03-27-2004, 11:58 PM
Okie02's Avatar
oh yea i have it in mind...the 228 cam i was refering to is also a TSP cam, but i think i will end up goin with the 231/237
Old 03-28-2004, 08:55 AM
1QWIKZ's Avatar
231/237 is a good split for nitrous..
Old 03-28-2004, 06:25 PM
Okie02's Avatar
ttttt
