chopperloco
05-03-2012, 05:58 PM
ROLLER $6000
PBM with red interior.
Ontario Branded-Rebuilt(salvage) Title,light upper right front end damage-fully repaired.The rest of the body is original paint and in nice condition minus a few light scratches dings.
No frame rail damage.
Parts replaced;Rad support and right and left frame braces,rad baffles(new GM)
Used;right fender,right headlight,hood,front bumper cover,battery tray,rad,fans,rad cover,upper grills
New AC Delco Battery
Stock steering rack has been converted to manual.
AC has not been replaced(did not have components)
Front K-Member has been blasted/powdercoated gun metal gray,engine mounts,Sway bar not installed(but incl.)
stock 04 catback.
Rear Diff;
Stock
Brakes;
Rotors turned and plated
Braided lines at rear calipers/machined banjo bolts for clearence/15" rims
Fuel Tank;
Stock with -10 fitting welded in/capped,-6 return in the top/capped
Still have the clutch pedal and stock drive shaft.
Weld RTS SOLD!
http://i148.photobucket.com/albums/s3/chopperloco/IMG00091.jpg
http://i148.photobucket.com/albums/s3/chopperloco/gto009.jpg
http://i148.photobucket.com/albums/s3/chopperloco/gto010.jpg
stock 04 catback.
Rear Diff;
Stock
Brakes;
Fuel Tank;
Weld RTS SOLD!
