BoostAntiDrug
05-08-2012, 10:59 AM
After a couple of months the old 346 was retired and in went a brand new LS6 347 with diamond pistons, eagle H-beams, clevite bearings, and ARP bolts everywhere possible. After a month and some break-in driving, on went the D1SC Procharger, methanol kit, then the tune. The engine has around 3000 miles on it now and 4 oil changes. I'm not sure how many miles are on the supercharger since I purchased it used.so recently I decide to go turbo and auto. Has a brand new th400 and pt88 turbo kit now. The car is apart and needs finished. Looking to sell everything make an offer.
The complete mod list from memory:
Engine: 347 w/LS6 block and stock crank Diamond -4cc pistons Eagle H-beam rods Clevite rod/main bearings ARP rod/main bolts and ARP head studs stock 317 heads Manley Dual valve springs (.660 lift) Yella Terra Roller Rockers Comp Cams Pushrods Comp Cams Lifters Double Roller Timing Chain set LS6 ported/shimmed oil pump TSP Custom Grind blower cam (spec'd by PredatorZ) Edelbrock vic jr /Nick Williams 90 Throttle Body Vengeance Racing Anodized catch can A
Poweradder:pt88 new pw44mm wastegate new. 3" Aluminum Piping w/ 4" Front Mount Intercooler SNOW Stage II progressive methanol kit Mondo Bypass Valve Walbro twin 255lph pumps Motron 60lb flowmatched injectors Aeromotive Fuel Pressure Regulator Aeromotive Billet Fuel Rails
Transmission and Suspension: th400 built by cooks / pct convertor UMI TQ arm/ adjustable LCA's/ PHB QA1 12-way adjustable rear shocks
Cosmetic: Eibach Pro Kit 15% window tint Triple gauge A-pillar Aeromotive Gauges - boost/fuel pressure/Air Fuel Mecham Hood (car is a Mecham Clone) Summit Aluminum Sport Mag Wheels Mickey Thompson 275/50/15 (700 miles) 165/15 in the front
Call or text for pics and more info. 864-921-4532
