ZL1Killa
05-19-2012, 12:25 PM
**NOTE : IDs are DIFFERENT part numbers, BUT yes generally speaking they are nearly the SAME BOSCH injector
*The cores are different, but BOTH are made from the same part number
On the 1000cc FIC uses the SAME part number.
On the 725 FIC uses a different pn. On the 850 same part and 2000 same part I cannot tell what Bosch PN the IDs are but these flow slightly different than each other
A LONG time ago when I was first going into forced induction, I wanted injectors that would give me some breathing room as at the time I was not very knowledgeable about all of my fueling needs and wanted to ensure I had enough. I ended up going through what it seems like everyone came across at that time and I selected 60# injectors to run with my base STS kit and my stock LS1. I had no injector data besides calculating my IFR values.
So I got the car all put together and the 60# injectors in and I flashed the car with the correct IFR and tune that I had put together getting ready for all of this. I cranked the car up and in Open Loop it ran rich for a little like normal and then heated up to closed loop and I noticed it was still rich. During idle, all I could run was rich 11.5:1; however during driving conditions, all was fine. I spent countless hours messing with it, trying to find a solution to no avail. I had no idea at the time, and even had help from people on ls1tech, still no solution. I was simply told to buy other injectors, or swap to smaller injectors.
So I read around and sold my 60# injectors and did some research and ran into Injector Dynamics and all of the write ups. Thinking these would solve all of my problems as all tuning data was provided, but heavily disliking the price compared to all other injectors of the same size. Wanting a fix I purchased them and all was fine, all problems were gone.
Pictures of ID Injectors:
http://i58.photobucket.com/albums/g242/zl1killaws6/2011%20Fuel/Injector%20Dynamics/DSC01795.jpg
Some things I noticed with them upon looking at the injector is that you can tell the part numbers have been taken off with a dremel.
http://i58.photobucket.com/albums/g242/zl1killaws6/2011%20Fuel/Injector%20Dynamics/DSC01799.jpg
I had the opportunity to own and use the ID725 injectors for quite some time now, and for some notes when I installed them, I had two O-rings that I had to replace as they didn't fit snug enough and leaked fuel, that getting fixed all was ok.
Now knowing what I know, I would have never bought those injectors, and I would have purchased the ones I have now, FIC725s. These are 69.56# injectors @ 43.5psi and I have all the data to properly tune them as well, they would have saved me some $$. FIC also included the clips to hold the top adapter piece to the injector.
I got the FIC725s and upon installation all of the O-rings were a nice snug fit, even had to put some elbow grease into a few of them to get them in. Absolutely no issues with them, they behaved equivalent to the ID injectors. The ID injectors were actually slightly smaller than the FIC injectors. ID flowed 725, FIC flowed closer to 732.
Pictures of FIC725s:
http://i58.photobucket.com/albums/g242/zl1killaws6/2011%20Fuel/P1040427.jpg
http://i58.photobucket.com/albums/g242/zl1killaws6/2011%20Fuel/P1040426.jpg
http://i58.photobucket.com/albums/g242/zl1killaws6/2011%20Fuel/P1040425.jpg
http://i58.photobucket.com/albums/g242/zl1killaws6/2011%20Fuel/P1040424.jpg
BOTH COMPARED:
http://i58.photobucket.com/albums/g242/zl1killaws6/2011%20Fuel/Injector%20Dynamics/tips_001.jpg
http://i58.photobucket.com/albums/g242/zl1killaws6/2011%20Fuel/Injector%20Dynamics/tips_002.jpg
http://i58.photobucket.com/albums/g242/zl1killaws6/2011%20Fuel/Injector%20Dynamics/DSC01803.jpg
http://i58.photobucket.com/albums/g242/zl1killaws6/2011%20Fuel/Injector%20Dynamics/DSC01801.jpg
http://i58.photobucket.com/albums/g242/zl1killaws6/2011%20Fuel/Injector%20Dynamics/DSC01800.jpg
ALSO,
the tuning data is slightly different for these as seen below, but the values WITHIN operating range of a typical vehicle are damn near identical.
ID OFFSET TABLE
http://i58.photobucket.com/albums/g242/zl1killaws6/2011%20Fuel/IDDATA_close.png
FIC OFFSET TABLE
http://i58.photobucket.com/albums/g242/zl1killaws6/2011%20Fuel/FICDATA_close.png
BOTH COMPARED:
ALSO,
ID OFFSET TABLE
FIC OFFSET TABLE
