Turbo 5.3 Monte Carlo
Old 05-21-2012, 10:02 PM
enzo354's Avatar
Default Turbo 5.3 Monte Carlo
Well, doing a fun little build in the 86.
The car
Well I got rid of the mystery motor.
And picked up this grand old beast
A good amount of nasty smelling crap under the intake.
What the hell happened here?
Needs a good old hone and she will be back up. After I order a few more parts of course..... A few.
Now I have a few questions as I start this.
As I sit now, I got the ms3 cam with 114 LSA. The motor has the 862 heads on it, and I got a set of the trick flow dual spring valve springs. My question is, with this set up will I need any fly cutting? Also what would you suggest I do pushrod wise?
Old 05-21-2012, 10:32 PM
the_merv's Avatar
I would do Chromeoly Pushrods. Clay it if you aren't sure.'
Just FYI..them Knock Sensors are supposed to come out before the Valley Cover comes off..
Old 05-21-2012, 10:46 PM
enzo354's Avatar
Alright, I'll check into it, and I cant get those sensors out for the life of me. 1/2 of the bolts on this motor are wither seized in or so rusty you cant use a wrench on them.
Old 05-21-2012, 11:28 PM
the_merv's Avatar
From the looks of it the Grommets pulled out of the Valley Cover.
Since you have it out try Channel Locks and twist them out.. It's not like you are trying to save them..
Old 05-21-2012, 11:51 PM
enzo354's Avatar
I'll give it a try. I just don't want them to crunch in and then not move.
Old 05-22-2012, 12:01 AM
the_merv's Avatar
You'll get them with Channel Locks.. I've done it with the Valley Cover on..
Old 05-22-2012, 01:33 AM
enzo354's Avatar
Haha sounds like it should be easy then. Beautiful Monte you have there btw!
Old 05-22-2012, 08:45 AM
the_merv's Avatar
Thanks.
Yours looks like its still factory paint, it's in good shape.
Old 05-22-2012, 10:16 AM
enzo354's Avatar
Originally Posted by the_merv
Thanks.
It's a "Night Time" looking paint. In the day you can see all of the swirls and haze and chips and dings, but cruising at night I'm not afraid to rod the **** out of it. *I live on gravel so this is a big statement haha*
Now I need to figure out if I want to go with a fuel tank from a v6 monte, or a fuel cell.
Old 05-22-2012, 12:11 PM
the_merv's Avatar
Same with mine.. Get up close and you see the small stuff. It's a driver.
Old 05-22-2012, 06:37 PM
IT_SS's Avatar
nice!
Old 05-23-2012, 12:21 AM
enzo354's Avatar
Thanks, now here is kind of a dumb question, I'm new to all of this wiring though haha.
When I install this motor, can I get by with just the ecm and the wiring to the motor and trans, or do I also need to pick up the under hood fuse box from a 5.3 truck? I've seen it done both ways.
Old 05-23-2012, 05:52 AM
t72ss402's Avatar
No questions are dumb. most people do not use them, but you can if you want to. Its is alot easier to set your harness up as a 4 wire hook up and just an after market fuse block and a couple of relays. here is some good info for you
http://www.lt1swap.com/wiringharness.htm
http://www.youtube.com/results?searc....0.xgD2taCON2U
These guys on this board are great for getting info from. So ask your questions.
Tim.
Old 05-23-2012, 05:02 PM
enzo354's Avatar
Thank you very much, that site has a ton of info. I'm going to try not to use it so that I can clean up the engine bay a decent amount.
Old 05-24-2012, 12:06 AM
enzo354's Avatar
Well the ms3 I picked up, with the 114lsa I was reading could be bad for my build. I'm going to sell it to my buddy with his gto and stick to a stock cam for now. I need the money to go into other parts anyway.
Old 05-24-2012, 06:41 PM
MillsMotorvation's Avatar
Any cam over stock is better than none. These engines love cams! Take advantage of those stock 15degree heads! I have a Z06 cam in mine, and it gave the car aprox400hp. See if you can get a cam. Jegs has the Z06 cam on sale for like $270 I think. Good luck!
Old 05-29-2012, 07:22 PM
IT_SS's Avatar
I'm thinking about leaving my 5.3 stock expecpt for bolts and intake & seeing what I can get with e85 & tuning
Old 05-29-2012, 11:34 PM
tta656's Avatar
Tim.
awesome info
Old 05-31-2012, 07:03 AM
speedfreak90's Avatar
man i hope the motor i get doesnt look like that... good luck with your build!
Old 06-20-2012, 08:48 PM
enzo354's Avatar
Brought home the motor from the machine shop, he never touched it so I went and got it....
Also, who sells a flexplate/ spacer to mate the 5.3 to a 4l80e? I have the tranny from a 1996 and Ive been searching but getting a run around.
Quick Reply: Turbo 5.3 Monte Carlo
