Vehicle Classifieds - 2001 som ss m6 60550 miles.
View Full Version : 2001 som ss m6 60550 miles.
heymoej
05-23-2012, 05:44 PM
First i am sorry for the long post,but this car has alot to offer......please read it all,i think it should answer just about everything.
Looking to sell my 2001 SOM M6 SS with t-tops.
Car has a clean carfax. Car has run flawless with zero problems.
this is a true M6 10 second street car, stock bottom end N/A.
jump in & go........
All motor work was done by Cartek,its there 4x package.
the m6 trans, six speeds inc reworked & it has a cartek clutch that is holding up great.
Rear end is a MWC fab9 with 456 gears.
At Cartek this car put down 475RWHP on their dynojet.
it has run 10.80 @ 128 all motor with a 1.51 60' & has more in it with a better driver!
Car has 60350 miles on it now & the motor has less than 3500 miles on it since cartek rebuilt it,i have most reciepts.
Mods are:
Motor
CARTEK built stock shortblock (LS1 block), stock crank and rods,ARP rod bolts, flycut stock pistons, CARTEK 4X cam, Comp R lifters, CARTEK 243 4X heads, Cometic head gaskets,CARTEK ported fast 90mm intake with nick williams 90mm t-body, Meziere polished EWP, 42lb/hr injectors, ASP underdrive pulley, rollmaster double roller timing chain,85mm maff,98mm lid,msd 2 step,Kenne Belle BAP, Katech tensioner pulley,chrss1313 ram air just installed May of 2012.
it runs great!
Trans
Sixspeeds Inc stage 2 built T56, CARTEK clutch, TICK adj master, Pro 5.0 shifter with lou's short stick.all of these have less than 3000 miles.
it shifts fine & the clutch is holding great!
Rear end
MWC fab9 powder coated black & back braced, narrowed 3" per side with aluminum yukon thru bolt center section,35 spline axles,yukon 4.56 gears on a spool, mwc long t-arm, Spohn dragbar, LCA relocation brackets & PST steel drive shaft, it has a drive shaft loop bolted in to the trans tunnel.rear end is pretty quiet......
Suspension
BMR k member and lower control arms, front and rear QA1's with 275lb springs up front & hotchkis 1" drop springs in the rear, BMR subframe connectors,
SJM rod ended chromoly lower control arms,Wolfe 6 pt. chromoly cage with swing outs, SJM ABS delete, SLP line lock.
all in great working order.
Exterior
Newer SOM paint, new emblem pro stainless ss emblems with stainless rear camaro fill ins & stainless nose emblem.
SLP SS car cover.
Interior
It has black scat procar front seats with black gforce cam lock 3in wide belts certified till 2012 on both front seats.stock monsoon radio & speakers with 12 disk in the rear, shift light, grant steering wheel & the horn does work, tan ozite light weight carpet.
Rims & Tires,Brakes
Bogart RT wheels.
15x4 front and 15x10 rear.
The rear rims are offset for the rear that has been narrowed 3" a side.
Included are the upgraded billet center caps from bogart.
Stock size long studs front and 1/2" rear studs.
Front tires are at 7/32 and rear tires are 5/32.
Front tires are M/T Sportsman S/R 26x6x15
Rear tires are M/T ET Street Radial 325/50/15
Brakes are new brakemotive drilled & slotted front & rear with there brake pads....
Exhaust
Hooker 1 3/4 headers (coated), TSP x-pipe true duals with dynatech race muffler with turn downs under the passenger seat area.(non bullet)
!mods
A/C, pass and driver airbag, steering wheel, rear seats, stock seat belts, front bumper support, rear bumper support, stock grill, side molding, spare tire & jack, front end link bar & brackets.
Since i bought it,it has 2 trips to the track in the last two years with about 10 passes total & the best it went was 10.8? @ 128 with a 1.51 60'.
i have not drove a stick in about 4 years & i am sure with a better driver it is capable of 10.5 in the quarter.with the new ram air,it should pick up 2 MPH & a tenth or two.........?
I bought it 7-5-2010 from mike (sickss228) for $12.500
i have done the following to it since @ the cost of over $8000.
New SOM paint,the clear coat was peeling, MWC fab9, Bogarts & tires, Scat procar seats with black gforce cam lock 3in wide belts, MSD 2 step, new msd wires with new plugs, new mobil 1 oil change, SLP SS car cover, brand new tan t-top shades,12 disk.brakemotive disk & pads.
and the emblem pro stainless SS emblems have not been put on it yet.
i have enough new synthetic mobil 1 atf for the next trans oil change.
mike the previous owner spent in the neighbor hood of $14000 not counting the cost of the car. i have alot of reciepts.....
The not so bad
The paint did not come out as well as i would have liked.dont get me wrong.its beautiful from five foot away but has flaws up real close.
a few of the speakers are on there last leg.the coating on the hooker headers is flaking & has seen better days.there is a small 1" crack in the dash.
last time i drove it i could not get the 12 disk to play...?
and i think one of the pipes on the true dualls might be cracked...?
Note
It has not been to the track with the MWC fab9 with the yukon center & gears...
we set it up at a negative 2 degrees,so some testing & dialing in of the suspension may be needed before a track visit,just to be on the safe side.the yukon center & 456 gears have about 300 miles on it......
PM me for best results......
Thanx John
bigbadblackws6
05-26-2012, 08:06 PM
if you ;paid 12500 for it then i will gladly give you 12500 for it. possible a little more but nothing near the 17k you are asking... beautiful car and i would love to have to but it needs a better price IMHO.
glws and bump for a great ride...
heymoej
05-26-2012, 08:13 PM
plus i put over $8000 more cash that i put in it............;)
yeah, i wish it was like this when i paid $12.500 for it..........
02gixxersix
05-27-2012, 08:08 PM
Looks like a nice car but I am kind of with Bigbad. I would think more around $13-14 since it was just a paint job and a rear end. Rear costs $2500 or so. Paint doesn't really count. Plus you drove it and tracked it. $13k would be a good price.
Racer001
05-27-2012, 08:12 PM
this site is such a pain to sell on, I swear.
You list something nice for sale and all the cheapskates come out of the wordwork, trash your car, says its worth less, and totally F up your for sale thread.
If it costs too much, then move on. Its obvious you wont buy it anyway, so why bring the man down?
heymoej
05-27-2012, 08:21 PM
thank you SIR!
i have bought 2 cars on here & have sold 3.
i know who is serious & who is not on here......its usually quite obviouse to tell the two apart.......i think you know what i meen. ;)
heymoej
05-27-2012, 08:27 PM
these parts are NOT cheap,i have over $4500 in the rear end & rims & tires.......go price just a thru bolt 9" case thats set up & ready for install.
have you priced a paint job lately?
so you are just a little bit off..........good try tho..........:confused:
your right i tracked it & so did the guy i bought it from & so will who ever buys it from me........and i drove it maybe 400 miles in 2 years & i am also 55 years old & treat my shyt right. ;)
heymoej
05-29-2012, 03:14 PM
i hope everyone had a good memorial day,i did.
god bless our troops!
sickss228
05-30-2012, 07:56 PM
Bump for a good guy and a great car! I put alot of time and money into the car before I sold it to John, someone is going to get a car that was put together right with no expense spared! Any questions about the car that John cant answer feel free to ask me. Good luck with the sale John! -Mike
heymoej
05-31-2012, 03:19 PM
hey mike,how are you & the new house?
thanx for the support & being able to answer any questions that might pop up!
you & me both put in alot of $$$$ in this car & it shows how it performs & looks......what was the mileage when i bought it from you 2 years ago,59955?
it has 60376 miles on it now.....everything done to this car has less than 5000 miles on it or less from all the work you & i have had done to it.
you would love the additions i have done too what you started!
New SOM paint base coat clear coat, MWC fab9 with yukon thru bolt case & yukon 456 gears with timken bearings, Bogarts RT rims 15x4 front and 15x10 rear & tires Front tires are M/T Sportsman S/R 26x6x15 & Rear tires are M/T ET Street Radial 325/50/15,Scat procar seats with black gforce cam lock 3in wide belts, MSD 2 step, msd wires with plugs, new mobil 1 oil change, SLP SS car cover, tan t-top shades,12 disk.brakemotive drilled & slotted disk & pads.chrss1313 ram air.emblem pro stainless SS emblems & rear camaro fill ins,autotrix passenger window fix..........
no more howling 12 bolt,that MWCFAB9 is a monster & with it being narrowed those deep dish bogarts look awesome on it.
and having it repainted to fix the peeling clear coat topped it all off......
the 2step is nice,first time i have had one.
set it for what rpm you want to launch at......push in the clutch & floor the go peddle......simple.
i forgot,we just put a Autotrix Passenger Side Window Fix & the passenger window works fine.....good product if anyone needs to fix a slow window motor.
mike,pm me if you like.....i sent you one about a month ago.....it might of got mixed up like the last one????
all other pms answered.......thanx.
94 s dime
05-31-2012, 11:10 PM
To the guys bringing the thread down , I bet this car is nice than advertised just as the previous Ss I bought off him was probably the nicest of 4 f-body's I've owned. Honest and upfront don't know if you'll find a better seller!
01 WS6 6.0
06-01-2012, 01:58 AM
X2 if you cant afford it GTFO and dont leave your .2 cents
heymoej
06-01-2012, 11:43 PM
joey,
thank you for the kind words......i am very happy you enjoyed your purchase!
yeah it seems pretty simple to do just that........
or if you dont have anything nice to say then dont say it or send it in a PM.?
97ramsst
06-01-2012, 11:56 PM
Are you making him an offer on the car or giving a worthless opinion on what he should sell HIS car for???
Really??? Seriously??? So if it had crappy paint on it you wouldnt expect to get it any cheaper??? Come on...
Its amazing how many broke ass experts there are on here.
GLWS OP...its a nice car and its your car...ask what YOU feel its worth!
TheLS1Lover
06-02-2012, 11:13 AM
I actually think its an fair deal. Its an H/C/I M6, SOM Car with low-ish miles for 17K.
GLWS.
heymoej
06-03-2012, 12:47 PM
that was my reasoning when i bought the car,i knew i had to have it repainted. so i made my offer on it with that in mind.....$$$$
thank you.
GLWS.
thanx man.....
also with built m6,fab9 & full suspension front to back......
91christineb4c
06-06-2012, 03:53 PM
Very nicely put together car! I have recently been trying to sell my trans am and get the same grief. I mean come on guys just because you think its worth less doesnt mean you need to tear his car down..you guys wont pay that much for it? GREAT now move on! Goodluck with sell! Very nice car!
forcefed6
06-06-2012, 05:13 PM
bump for OP, !!! GLWS
heymoej
06-07-2012, 05:45 PM
thank you,
sorry for your grief......good luck on your endeavor!
thanx man! hopefully it will make a new owner happy.....
went to a cruiz in last night, so mileage is now a little over 60405.
ran like a champ...........
adamantium
06-18-2012, 12:02 PM
wow some people are retards, this car has a TON of quality parts, and being that it is a low mileage ss it is definitely a great buy especially since its an SOM car :P GLWS!
heymoej
06-19-2012, 11:32 AM
thanks!
a ton of quality parts = a ton of $$$$$ & then some.........
http://ls1tech.com/forums/attachments/automatic-transmission/359473d1340062298-whats-real-differences-between-375-converter-700-one-photo-01.jpg
heymoej
07-10-2012, 06:51 PM
had a friend come by with his 21 year old son out of the blue & look at the car over this last weekend......
he says he wants it & is checking out his options.
i dont think i could sell it to him & feel right about it.?.? i think its way too much car for him.
heymoej
07-28-2012, 02:16 PM
i guess my buddy's kid cant get financed....
mileage is now around 60500.
W8S SS
08-02-2012, 09:31 PM
Man that thing is sick. I'm gonna be seriously interested in a SOM SS when I return from overseas
camd01silv
08-02-2012, 10:06 PM
Very nice car indeed. I read in there somewhere that it used to have a howling 12 bolt? Don't mean to hijack, but I have to ask. My 12 bolt is annoying with its howling. Are the 9" rears easier to live with? But back on track with your car... I tried selling mine a year or so ago and was asking about 12k... IMO 12k for my car with what it has done and the quality of parts and workmanship was a helluva deal, but I still had folks trying to lowball me. It doesn't have near the work done that yours does but its cleaner and nicer than 90% of the f-bodies around here. Anyway, good luck selling it, from what I've read it's sure worth it.
heymoej
08-02-2012, 10:22 PM
thanx!
be safe!
i hope you find a good one when your ready. :cheers:
no problem......yeah the 12 bolt was louder than the motor,the radio and anything and everything i have ever heard.
thanx!
pm sent......
camarodude87
08-04-2012, 07:29 AM
This car is DEF worth the asking price. If I would of seen this car two yrs ago Id be all over it. I paid 12k for mine SOM SS STOCK... and invested well over 13k into mine. super nice car, perfect mods. Great price. Good luck to you on selling this car
Z/YA
08-04-2012, 08:40 AM
I've seen the car in person, actually I believe I bought the first set of race wheels off is it when he bought the new wheels an Fab9 rear. It's a very nice car!! The new owner will not be disappointed!!!
heymoej
08-04-2012, 05:56 PM
thanks!
yep,the money is already spent & the work done.....:drive:
thanks!
i hope the rims & tires worked out for you.....:cheers:
it wont hurt my feelings to keep it.....thats for darn sure.
97z2801ss
09-02-2012, 05:49 PM
I love the SOM color so free bump.
We've had ours since 02 and still get asked how much we want for it all the time! GLWS!
For the people that think it's to much, there are other SOM cars on here in your price range!!!!
heymoej
09-03-2012, 04:03 PM
damn,you have had yours for awhile!
maybe i dont drive mine enough..........:secret:
i think it is about the best color on a 4th gen.
thanx! ;)
heymoej
09-11-2012, 05:24 PM
Bumparoooooooski.........
also will take a partial trade on a small truck with 4x4.......like a ranger or what ever.
X R8TED
09-16-2012, 08:04 AM
you should drop the price,17k is just too much in this economy, the car is nice but i highly doubt the bank will give that much money on a car that old,but good luck with your sale i hope you find a good buyer, why did you use stock pistons???
heymoej
09-17-2012, 05:18 PM
its gonna take somebody with some cash laying around & i know thats far & few between these days.
i understand banks will not lend that much for this year car....not much i can do about that.
its a flawed system........
thats how cartek does there 4x package,stock pistons,stock crank....
car looks good runs strong & has a ton of money in it with low miles :burn:
thanx for the bump ;)
gillbot
09-30-2012, 09:47 AM
I stopped trying to sell mine on here, i'd rather deal with the morons on craigslist than here.
jsmith564
09-30-2012, 10:09 AM
Money isn't plentiful among the general public. Advertise it at the track. I wasn't serious at the time but had a couple older guys who like to bracket race who wanted my car.
As far as your car goes, i know the money was spent. I have $17k in building mine. Errrr. It don't look as good as yours either. Min i would take is $11. try building one of similar build and quality, it's hardly possible if at all possible.
All the negative people should quit posting. It's a quality car, he owns it, he can ask whatever he wants, he doesn't need or asking for any advise to help sell it. It takes only one buyer with means to own such a nice car. Please stfu.
heymoej
10-01-2012, 03:49 PM
its what makes the world go around.......:D
you have a sweet ride ......dont give it away :chug:
yep,its all good.......if it goes it goes,
if it dont i might just put an a4 trans in it next year.
so i can enjoy it more. :D
i have 3 blown disk in my neck & a bum left leg.....when i am feeling frisky & i do drive it,it beats the shyt out of me when i hit the go pedal. :bang:
thats another reason its not been to the track....i physically can only handle 2-3 passes in it & then stick a fork in me cause i am done. :emb:
and yes thats with a safety neck brace under my helmet.
my last car was an auto car that would 1.45 60'.
i could tolerate it alot better than this m6 @ the track with a 1.51 60'......
so i have that option to play with if it dont sell.
thanks!
Raoul-Duke
10-05-2012, 03:17 PM
I think this is a great deal. It is absolutely insane what some people say cars are worth on here when thousands and thousands are invested. Stock 6 speed F-bods with same mileage are going for 13k on autotrader and SELLING. Nice car, good deal.
heymoej
10-06-2012, 04:08 PM
its got alot of quality parts in it,plus time & effort.
thanks!!! :chug:
heymoej
10-20-2012, 01:47 PM
to the top......................trade for a 4x4 truck.
SSickLS1SS
10-20-2012, 02:06 PM
first time seeing this thread, i think this car is worth every penny, gl with the sale, try cars.com or autotrader maybe youll get a few more bites.
heymoej
10-21-2012, 01:58 PM
maybe i dont bump this thread enough......thanks!
gillbot
10-21-2012, 04:23 PM
I don't think it helps. I gave up on trying to sell mine. I've had more than a dozen people make arrangements and not bother to show up.
heymoej
10-22-2012, 11:33 PM
that seems like the norm.........you still have a very nice car!
i am about ready to take off the insurance & just park it & leave it for winter...its not like i really drive it.
my left knee is totally shot & i dont even know if i could drive it if i wanted toooo.
gillbot
10-25-2012, 05:44 PM
I let the plates on mine expire and I put storage insurance on it. It can wait till next year and i'll either demod it and trade it in or drive the crap out of it.
heymoej
10-27-2012, 12:03 PM
yep,its that time again....it was like 33 degrees here early this morning.
took it for a little drive to stretch its legs a bit & try my knee out....its got a little over 60500 miles on it now.
heymoej
01-23-2013, 05:13 PM
after new years bump...........
heymoej
03-22-2013, 02:03 PM
bump.....
heymoej
04-02-2013, 08:40 PM
ttt tttt ttttt
1973LQ9T56
04-11-2013, 03:31 AM
Can u pm me pleAse. Thanks
heymoej
04-13-2013, 02:22 PM
nice talking to you!
thanx for the bump :chug:
SPAZ-3
04-13-2013, 09:52 PM
i love and want a SOM M6 car so bad and wish i had the money but 15500 seems a lil too steep:/ bummer if only if only
heymoej
04-13-2013, 10:21 PM
i can always start pulling parts..............:chug:
1973LQ9T56
04-14-2013, 01:30 AM
Thanks so much for being understanding, I really wish u the best and I will be happy to give this post a bump periodically. Best of luck.
big reg
04-15-2013, 09:49 AM
Good luck. Nice car and parts list. It seems only 5-10k clapped out and ragged f-bodies sell on here. If its nice with a ton of add ons that most could not afford to do themselves, than it is over priced blah blah. The same guys buying those cars make threads like hey can I install the Mega Cock 6 cam and still use a single spring as I can't afford duals right now
List it on auto trader as well. Lot more serious buyers browsing there with money to actually spend. F-body's and Gto are older and financing is harder. Cash buyers are needed. If I had a dollar for every clown that was buying my car but now can't get financing I could put a blower on my car.
heymoej
04-15-2013, 11:30 AM
WINNER WINNER......CHICKEN DINNER. :chug:
THANX MAN! :D
1973LQ9T56
04-17-2013, 02:24 AM
Glws!!!
heymoej
04-19-2013, 11:40 PM
Glws!!!
thanx bump :chug:
Black FormulaLs1
04-20-2013, 02:42 PM
what about a whole bunch of pics? undercarriage engine bay etc?
heymoej
04-20-2013, 03:01 PM
i hear you.........i am working on that!
right now, it is dusty inside and out from just sitting.
i am guilty of that for sure.........:eyes:
i am trying to find a detailer to detail the car before i take new pictures.:chug:
any detailers in my area (46356 N/W IN.) that want to make some quick cash,please PM me!:D
also my brother who is a detailer and runs a shop in NEVEDA, is suppose to be coming out for a visit real soon.....any week now.
to be honest, i kinda been waiting on that too.....i was gonna hit'em up
for the brother & helper price.lol. :corn:
heymoej
04-27-2013, 05:59 PM
ttt tttt ttttt
blazinhd
04-29-2013, 10:09 PM
this is a great deal i paid 14 for at the time my bone stock 2000 TA with 75k on it your a hell of a man i would of bought this in a heartbeat bump for a great guy...by the way i seen this is cl lol i live in demotte
heymoej
04-30-2013, 12:15 PM
my daughter lives in the big D....i am in lowell.:burn:
yep,good old CL......i have had alot of recent offers.....:bomb:
THANX! :chug:
heymoej
05-06-2013, 08:32 PM
ttt tttt ttttt
heymoej
05-16-2013, 07:44 PM
back toooo the top!
took her for a little ride a few days ago............ran like a champ,as usual!
William625
05-16-2013, 09:02 PM
I actually think its an fair deal. Its an H/C/I M6, SOM Car with low-ish miles for 17K.http://mpe.cmisoftware.com/6.jpghttp://mpe.cmisoftware.com/7.jpghttp://mpe.cmisoftware.com/8.jpghttp://mpe.cmisoftware.com/9.jpg
