Generation IV Internal Engine - LS7 rocker arms fit LS3?
View Full Version : LS7 rocker arms fit LS3?
CarlL
05-26-2012, 03:46 PM
Greetings everyone....newbie to this site....has anyone done, or know if you can swap the 1.8 LS7 rocker arms in place of the 1.7's in the LS3? And if you can, do you need to swap the p/r's and springs also?....
All the GM parts sites that I have seen list the LS7 rocker arms for the 6.0, 7.0, and 6.2.
Thanks in Advance!
litle88
05-26-2012, 05:09 PM
Don't know where your looking but no the intake rocker arms are different. Exhaust are the same though.
CarlL
05-26-2012, 08:14 PM
I know, the intakes on the LS3 are offset by .246" http://www.camarohomepage.com/ls3/page4.htm as per/this link, does the LS7 rocker have the same .246" offset?, and can it be intalled on the L92 heads?
litle88
05-26-2012, 11:32 PM
Noooo
Wnts2Go10O
05-26-2012, 11:35 PM
nope. the heads are different to the point that it cannot be done.
CarlL
05-28-2012, 11:28 AM
Ok, thanks guys!....this forum seem to have alot more "factual" information than others....
Gray86hatch
05-28-2012, 12:17 PM
the distance from the rocker bolt to the center of the valve tip is almost 1/4 futher on a ls7 head. I had a ls7 rocker in the shop I compaired it to a LS1
Tim
S10xGN
05-28-2012, 09:17 PM
Tim
Tim, the OP was asking about LS-7 vs LS-3, but they are still different offsets...
Gray86hatch
05-28-2012, 09:58 PM
It dosn't change that the ls7 rocker on the exh would overhang the valve tip by almost 1/4"
Tim
Jablowme
06-06-2012, 11:47 PM
ls7 rockers are 1.8 ratio lsx are 1.7
