Sponsored by: DashLynx
Shifter Plaque Install Question?
Old 05-27-2012, 10:43 AM
Bowtie-Bri's Avatar
Default Shifter Plaque Install Question?
This might be a stupid question, I'm going to replace my stock shifter plaque with this: http://www.afterthoughtsauto.com/35ancass.html
My stupid question is what's the best way to remove the stock one?
I assume that you need to get something underneath to pry it up, but that's easier said than done with out scratching the surrounding surface area.
Anyone here replace their's and how did you remove the old one?
Thanks!
Brian
Old 05-27-2012, 03:39 PM
Bowtie-Bri's Avatar
Wow, almost a hundred views.
I guess no one here has ever done this before.
Thanks any way.
Old 05-27-2012, 05:05 PM
luna123black's Avatar
Give it some time some one will reply. I'll make a suggestion although iv never done it. If it was me is probably take some piano wire and slide it under the lip of the plaque. And slowly pull it under to cut the adhesive behind it.
Old 05-27-2012, 06:14 PM
Derrick1227's Avatar
Never done this either but I agree piano wire or fishing line will work.
Old 10-13-2013, 04:37 AM
Scoobie's Avatar
Run into the same problem. Have one collecting dust. Website states it is designed to fit over the stock one. I assumed it would be notched but its flush and therefore doesn't fit.
Quick Reply: Shifter Plaque Install Question?
