Truck crossover kit with GT45R turbo- SOLD
Category: Engine - Power Adders
Price: $2350
Location (State): CA
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
This turbo has less than 3000 miles on it and made great power on my LQ4 with th400, 91 octane california pump gas.
this turbo goes new for 2800$
comes with the following
Truck manifold crossover pipes- stainless tig welded with 44mm wastegate flange
tial 44MM gate available for 200$ more ( new is 375)
4" downpipe - side dump out the bumper ( compatible with DMH 4" e-cutout)
3" over K-member downpipe for when E-cutout is closed
garrett GT45 80R turbo ( 80MM dual ball bearing)
two stainless braided -6AN water lines pre-assembled. I used my heater hose connection to drill out and weld -6AN fittings to it.
my car ran a 10.5 @ 135 no transbrake no launch 2.0 60 foot. 91 pump gas.
http://youtu.be/j-5FFcbuU-U
PM is interested will accept VERIFIED PAYPAL addresses only, money order/check or local pick up in san jose.
upon removing
i cant say i really ever took any pictures of it after it was installed.
i had 3" intercooler piping all around. i can throw in the hot side intercooler piping but its built for my intercooler and the end of the alum tube got crimped a bit.
i used the vertical griffen radiator setup with a pusher and puller . the oiling was a -10AN return ( no sump or pump needed) and a -4an feed . I reused all this stuff in my car
no damage clean blades.
1.28 AR turbine housing
compressor housing with welded on elbow
clean compressor wheel always filtered
NO OIL SEEP WHATSO EVER. does not leak a drop of oil. compresor housings clean, outlets clean, turbine housings clean
