Screwed up ordering tires...
So I ordered some new tires online and, like an idiot, I didn't double check the sizes. The sizes CURRENTLY on my 2002 z28 (with 17in rims in the front and 18in in the back) are: front-275/40 17 rear: 285/35 18. The front ones I ordered are fine, 275/40ZR17, however I got 285/30ZR18 for the rears.
Will there be any big difference? I know that the number is how much sidewall there is, but 5mm shouldn't be too much, right? Or am I going to have to order 35 and return the 30's.
UNDER PRESSURE MOD
If you haven't mounted them yet, I'd call up Tire Rack and explain to them the error and see if they will work with you to correct it. If it was the other direction, I would say live with it, but your rear tire is going to be shorter than the front and give it a weird raked look, and it's going to hurt traction having the shorter sidewall as well.
