Gears & Axles - Axle swap
View Full Version : Axle swap
nbmZ
06-09-2012, 12:27 PM
I broke an axle shaft and cant get the broke piece out. I have removed the c clip and required steps. Any suggestions?
pic for reference
https://sphotos.xx.fbcdn.net/hphotos-snc6/s720x720/248196_3272697339245_804930712_n.jpg
therabidweasel
06-09-2012, 09:32 PM
I assume the rear is still in the car? 3+ft pipe and a hammer to drive it out from the opposite axle tube or pull the diff and get it out with a shorter piece. Hopefully the diff isn't galled, let us know how it turns out.
How'd you break it?
nbmZ
06-10-2012, 12:08 AM
the housing is fine but the carrier and the carrier bearings are trash. I had to remove a lot of pieces from the axle housing and then used the old axle to push the broken piece into the carrier further. After that I just removed the carrier and replaced it with another one.
nbmZ
06-10-2012, 12:09 AM
https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-ash3/s720x720/167411_4168067162880_275357384_n.jpg
nbmZ
06-10-2012, 12:15 AM
https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-ash3/560425_4169288953424_201168730_n.jpg
https://sphotos.xx.fbcdn.net/hphotos-ash3/s480x480/554823_4169289673442_815743548_n.jpg
nbmZ
06-10-2012, 12:17 AM
Why was this carrier different than the one I used to replace it? There were no clutches in it.
I have only seen them with clutches and spider gears that look totally different.
nbmZ
06-10-2012, 12:25 AM
http://youtu.be/ypIaHTVVI3Y
02chickenhawk
06-10-2012, 04:04 AM
I'll sell you my auburn posi and axle shafts.
therabidweasel
06-10-2012, 05:37 AM
Can't see the pic you posted with the video but the one you posted above I believe is a zexel torsen posi, auburns have clutches. I've never worked on a torsen, so I'm not 100%, but that's what I think you had.
FirstYrLS1Z
06-10-2012, 05:57 AM
Since you don't have a 'sig' and you should have as that would allow us to answer your questions without having to guess what your car is and what mods it has.
99s' and later came with Torsen differentials.
98s' and earlier came with Auburn differentials.
Sounds like you used an Auburn to replace a Torsen.
Torsen parts are sellable,the 'paddle' block wih cross bolt,the end cap & bolts.
nbmZ
06-10-2012, 01:41 PM
Updated sig
FirstYrLS1Z
06-10-2012, 06:04 PM
increased engine power,better clutch,& big Nittos help explain the broken axle.
