Fueling & Injection - Open header read fresh air?
FNSlow
06-09-2012, 08:28 PM
I just put an ls1 back in the car with 30lb injectors and mild cam. We kept messing with the tune and the computer keeps trying to add as much fuel as possible. We even put a complete stock tune with 30lb injector tables in but the long term keeps maxing at 25 and the short term goes to add over 40 before I cut the car off. Can the O2s be reading fresh air because its open header?
86lxnotch
06-09-2012, 10:19 PM
how far from the end are the sensors? it could be reading some fresh air
lemons12
06-09-2012, 10:28 PM
Yes... It is why you kill o2s when you run open headers. Put a couple ft of piping on them.
My6speedZ
06-09-2012, 10:40 PM
This ^^^
Plus doesn't adding a couple ft of pipe help the exhaust velocity/scavenging?
lemons12
06-09-2012, 10:56 PM
This ^^^
I'm not sure.. I have seen tests back it both ways so I'm torn with that.
My6speedZ
06-09-2012, 11:27 PM
Yeah I've seen a few test where a good full exhaust flowed better than open headers back in the day when I was into Honda's but I don't know about open headers vs extenders.
FNSlow
06-09-2012, 11:31 PM
Thanks, I'll try to find some 3'' pipe locally tomorrow and see if it fixes the fueling
FNSlow
06-12-2012, 12:37 PM
That was the issue. Adding a foot of pipe made a huge difference
lemons12
06-12-2012, 01:49 PM
Glad you fixed the issue..
JoshuaGrooms83
06-23-2012, 04:29 PM
had a question about this as well but not dicrectly abuot open headers. If i have a leak between the cat and the LT headers, will this cause a fresh air condition as well with the O2 sensors? i have a NOTICABLE leak on my passenger side collector due to a horrible weld job that is failing now after two years on my SS steal headers to aftermarket cats. kinda pissed.
but would this cause irregular running conditions?
99Bluz28
06-23-2012, 04:45 PM
It actually recommended (at a minimum) to add 10X the collector diameter in pipe length to avoid the O2s from reading outside air. So for a 3" collector you'll want 30" of pipe.
99Bluz28
06-23-2012, 04:53 PM
If your gas mileage dropped a fair amount, I would say yes. I'd also pull a plug from the driverside and passengerside and compare them, they should look the same, if not thats more proof for you there..
FNSlow
06-27-2012, 02:15 PM
I doubt a leak from a bad weld will let any fresh air in to offset the front O2's
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
