gnx
06-11-2012, 04:22 PM
I HAVE INVESTED OVER 45K IN THE CAR AND ALL THE PARTS/ I HAVE AT LEAST 20K IN THE ROLLER IT IS MINT LOOKS LIKE NEW THE PAINT IS PERFECT COMPLETE COLOR CHANGE EVERYTHING WAS TAKEN OF THE SHELL PAINTED AND PUT BACK. I WAS BUILDING A SHOW CAR THE ROLLER IS FINISHED ALL I HAD TO DO WAS INSTALL THE MOTOR AND TRANS AND TUNE IT/ I WOULD NOT SELL IT BUT I HAVE TO BY A WHEELCHAIR AND SOME OTHER THINGS BECAUSE I WAS CRIPPED IN A CAR CRASH AND NOW NEED THE MONEY I WILL SELL THE ROLLER FOR 8500 AND THE COMPLETE SET UP FOR 25K AFTER THE ROLLER I WILL SELL THE NEW PARTS AT A DISCOUNT
THKS PLEASE PAST THE WORD AS I REALLY NEED TO SELL IT.
1999 TRANS AM INTERIOR IS GRAY LEATHER, ALL STOCK ,AND IN GOOD CONDITION.. ALL WINDOWS ARE TINTED 10% REALLY DARK.EVERYTHING WORKED AT TIME OF DISASSEMBLY.HAS AFTERMARKET CHROME RIMS,I HAD NO INTENTION OF REUSING THEM WITH NEW BODY WORK.T-TOPS PERFECT.
16K WORTH OF BODY SHOP WORK ,AND PAINT COMPLETE COLOR CHANGE (HOUSE OF COLORS) TANGELO PEARL INTERIOR FLOOR PANELS PAINTED ALSO.
ALL ELECTRICAL PARTS THAT ARE UNDER THE BODY PANELS OR HIDDEN AND HARD TO GET TO HAVE BEEN REPLACED(SO NO PANELS WOULD HAVE TO BE REMOVED FOR REPAIRS IF EVER NEEDED)
HEADLIGHT DOOR MOTORS,WINDSHIELD WASHER PUMP,ALL LIGHTS,HORNS,TOO MANY SMALL PARTS TO LIST.ALL UNDERSIDE PLASTIC,& FENDER WELLS COVERS ARE NEW,ALL LENSES,EVERY PART HAS BEEN PAINTED BEFORE BEING REINSTALLED. BODY WAS COMPLETELY DISSEMBLED AND PAINTED PIECE BY PIECE. ENGINE HARNESS COMPLETELY REDONE,RE-LOOMED,ALL WEATHER STRIPPING REPLACED,NEW RAPTOR RAM AIR HOOD.ALL FRONT BUMPER SUPPORTS REMOVED AND REPLACED WITH BURKHART CHASSIS SUPPORT..UNDERSIDE COMPLETELY STRIPPED AND CLEANED AND REINSTALLED ALL PARTS.FUEL TANK REINSTALLED WITH 340 PUMP KIT RACETRONICS HARNESS KIT,NEW SPRINGS,FRONT AND REAR SHOCKS,MOUNTS,SPRINGS SUPPORTS ETC..EVERY STOCK SUSPENSION PART HAS BEEN REPLACED WITH EVERY BMR PART MADE FOR THE CAR INSTALLED. NEW POWER COATED SPINDLES.FRONT SPLITTER
EVERY NUT AND BOLT PAINTED BEFORE BEING REPLACED,
DOOR HINGES REDONE,THERE ARE JUST SO MANY PARTS REPLACED IT CAN NOT BE LISTED EVERY BODY PART WAS REMOVED. NEW POWER RADIO ANTENNA
LOJACK INSTALLED
HAVE STEREO SYSTEM TO INSTALL FROM ANOTHER CAR/(MTX)10INCH SUBS/SPEAKERS 6X9 ALPINE(REAR) (FRT) CROSSOVERS MIDS AND TWEETS ALPINE/MTX 1200 WATT AMP FOR SUBS/4 WAY 600 RMS THINK ITS ALPINE
LISTING OF NEW PARTS INSTALLED DURING BODY SHOP ASSEMBLY ( AFTERMARKET & GM )
6LITEREATER DESIGNS FRONT SPLITTER ( $450.00 NOT INSTALLED)
SUN-COAST RAM AIR RAPTOR HOOD $760 PLUS SHIPPING $150.00
ALL NEW LENSES $150.00
HEADLIGHT DOOR MOTORS $600.00(GM),WATER BOTTLE MOTOR,HORNS,POWER RADIO ANTENNA, ETC..ALONG WITH ANY ELECTRICAL PARTS UNDER THE BODY PANELS
WERE ALSO REPLACED WITH GM PARTS(TO PREVENT HAVING TO REMOVE ANY PANELS AT LATER DATE FOR REPAIRS) ABOUT $800.00
ALL NEW GM WEATHER STRIPPING $500.00
NEW BODY PARTS (GM)
NEW INNER FENDER WELLS (GM)
ALL UNDERSIDE PLASTIC PARTS WERE REPLACED (GM)
DOOR HINGES REPLACED
WIRING HARNESS RE-LOOMED AND CHECKED FOR ANY ISSUES $300.00
6 LITEREATER DESIGNS BLANK GAUGE CLUSTER TO INSTALL AUTOMETER GAUGES IN PLACE OF STOCK CLUSTER $40(NOT INSTALLED)
ALL BELOW INSTALLED IN ROLLER
PROTHANE MOTOR AND TRANS MOUNTS. $200.00
NEW SPRINGS,MOUNTS,STRUT MOUNTS $350.00
NEW TOKICO HP SERIES PERFORMANCE FRT AND REAR SHOCKS $440.00
BMR K-MEMBER LS1 SET UP FOR FACTORY MOTOR MOUNTS $520.00
BMR ADJUSTABLE FRT UPPER AND LOWER CONTROL ARMS $440.00 & $350.00
BMR FRT AND REAR SWAY BAR KITS 35MM & 25MM HOLLOW $ 400.00
BMR REAR LOWER ADJUSTABLE CONTROL ARMS $280.00
BMR PANHARD ROD ADJUSTABLE $149.00
BMR PANHARD ROD RELOCATION KIT $ 210.00
BMR TORQUE ARM ADJUSTABLE BOLT ON $ 399.00
BMR 4L80 TRANSMISSION (CONVERSION) CROSS MEMBER /TORQUE ARM RELOCATION MOUNT $249.00 (INTENDED INSTALLING 4L80)
BMR DRIVE SHAFT SAFETY LOOP & TUNNEL BRACE $110.00
BMR SUB FRAME CONNECTORS BOXED WELD ON $170.00
BURKHART FRT CHASSIS AND BUMPER SUPPORT $250.00
GM POWER COATED SPINDLES $300.00
ALL BELOW NEW STILL IN BOXES
NASTY PERFORMANCE BILLET FUEL RAILS & F-BODY FUEL LINE SYSTEM,ALL FITTING NEEDED TO CONNECT TO STOCK FUEL LINE $339.00
60LB INJECTORS MOTOTRON $ 385.00
RACETRONIX 340 PUMP AND HEAVY DUTY HARNESS WITH EXTRA GROUND CONNECTION $249.00
FAST 102MM INTAKE MANIFOLD PORT BY TONY MAMBO FROM AFR(WORTH 15 TO 25 RWHP OVER STOCK 102) $900.00,$250 PORTING,$200.PAINTING= $1350.00
FAST INTAKE PAINTED TO MATCH VALVE COVERS (LSX454)
102MM THROTTLE BODY $359.00
COOLANT CROSS OVER PIPE KIT (GM PARTS) $109.00
TCI 8 BOLT FLEX PLATE $220.00
LINGENFELTER CONVERTOR BOX 58X TO 24X $220.00
ARP BALANCER BOLT $30.00
NEW GM OIL DIP STICK & TUBE $30.00
NEW GM OIL PUMP PICK UP TUBE AND SCREEN $50.00
MSD 3 HP LS1-LS7 STARTER $ 239.00
KOOKS 1 7/8 LONG TUBE HEADERS WITH LS7 FLANGES $1250.00
KOOKS COMPLETE DUAL EXHAUST WITH X PIPE POLISHED MUFFLES AND QUAD TIPS,(THIS KIT WAS THE VERY FIRST PRODUCTION UNIT SHIPPED)
UNIT IS MARKED AS THE FIRST KIT,GOOD TO 1200 HP DUAL 3 INCH ALL THE WAY BACK. (THE FINEST KIT ON THE MARKET) $1900.00
LSX 454 GM CRATE MOTOR 620HP,590 TQ(WILL MAKE MORE WITH THE PARTS INCLUDED) BRAND NEW AS FROM GM.STILL SEALED $10,400. WITH TAX
ALL ENGINE BRACKETS HAVE BEEN POWER COATED $250.00
NEW GM F-BODY OIL PAN PAINTED TO MATCH LSX BLOCK $ 220.00,PAINT $100.00
LATE MODEL GM 4L80 TRANSMISSION
ELDEBROCK LS1 WATER PUMP HIGH FLOW
EVANS HIGH FLOW THERMOSTAT AND HOUSING
ABOUT 44,000.plus INVESTED, OR AT LEAST THAT IS WHAT IS LISTED ABOVE,THERE ARE SOME PARTS I HAVE FORGOTTEN TO LIST
THIS CAR WAS BUILT TO BE A SHOW CAR THE UNDERSIDE IS PAINTED AND SPOTLESS,THE FLOOR BOARDS UNDER THE CARPET ARE PAINTED. IT WAS ALSO MEANT TO RUN 9'S ON SPRAY SHOULD BE ABLE TO RUN 10'S OFF THE BOTTLE WITH THE A/C ON (LOL).
I WAS CRIPPLED IN A MOTOR CYCLE CRASH AND JUST HAD SURGERY THAT WENT WRONG WE BELIEVE I WONT BE ABLE TO DRIVE AS I AM FROM THE CHEST DOWN UNABLE TO MOVE AND HAD TO HAVE MY NECK FUSED DUE MY SPINAL CORD SPLITTING IN TWO LAST MONTH
I HAVE ANOTHER 50 PICTURES OF THE COMPLETE BUILD FROM DAY ONE .THEY ARE ON ANOTHER PHONE FOR ANYONE INTEREST I WILL TURN THE PHONE ON AND SEND THEM.IT SHOWS THE CAR TORN DOWN TO THE CHASSIS AND BARE FRAME RAILS BEING PAINTED THKS. PLS LEAVE ANY COMMENTS OR IDEAS THKS
MARKIMM@ROCKETMAIL.COM
LOJACK INSTALLED
NEW BODY PARTS (GM)
