Screenshots of my tune
I'm new to tuning so I'm not sure what I can believe here. 1993 LT1 Trans Am starts, you can drive it for a few minutes, then it shuts down once it is hot. Doesn't throw codes. Sometimes floods itself at startup. Here is what the screen looks like. I have errors on injectors and the right O2 indicates lean. The engine runs lean (plugs are white powder). Closed loop time out. I have the Autoprom but haven't messed with it yet. So, what do I do?
Comp Cams 503, Ford redtop injectors (reman), Yank 3000 stall, 10.8:1 compression. Heated injector conversion (1995 LT1 injectors). The tune is from PCMforLess.
