Verifying Fuel Enrichment?
Old 06-20-2012, 07:50 PM
gMAG's Avatar
Default Verifying Fuel Enrichment?
I have a mailorder tune.
Is there a way I can verify with AutoTap, how accurate the air/fuel tables have been set?
Old 06-20-2012, 08:43 PM
joecar's Avatar
You really need a wideband (lets you compare measured AFR against commanded AFR).
Old 06-20-2012, 08:51 PM
gMAG's Avatar
Thanks, Joe.
Old 06-21-2012, 09:59 AM
got-a-ls1's Avatar
yep wideband is the first thing to buy if you want to tune a efi engine, followed by tuning software lol.. for 200 bucks it amazes me how many people wont buy one.
Old 06-21-2012, 11:03 AM
joecar's Avatar
During closed loop you could look at the LTFT's, these will be close to zero if the MAF (steady state airflow conditions) and the VE (transient conditions) are correct.
But, anything outside of closed loop a wideband is required (e.g. at WOT you can't rely on HO2Sx1 voltages being above some value since these are not "calibrated" to provide voltage:AFR conversion; some people are lucky and get away with this, but it is a bad idea).
Old 06-21-2012, 03:00 PM
gMAG's Avatar
Joe,
^^^LTFT's is the theme I was looking for....just a way to verify closed loop enrichment. There are a couple of issues happening. First one is overly rich @ idle, and maybe rich off idle. I have P0154 bank2 -1. Then, an idle motor stuck on zero.
Once the bugs are worked out, the car will be dyno-tuned.
Thanks!
Old 06-21-2012, 03:54 PM
joecar's Avatar
Glenn, you see where this is going... (you're heading towards learning how to DIY tuning)
Old 06-21-2012, 05:46 PM
gMAG's Avatar
Yes, sir!
I hope to ascend to the rarified air of the LS1 kingdom!
Old 06-22-2012, 10:39 AM
joecar's Avatar
lol, it's not rarified anymore, there are too many people doing it, it has become a must for the DIY/carguy.
Old 06-27-2012, 05:36 AM
crainholio's Avatar
Originally Posted by gMAG
Joe,
IAC going to zero usually means unmetered airflow from a vacuum leak, or somebody screwed with the TB and it's letting in too much air at idle.
Old 07-01-2012, 01:03 PM
JoshuaGrooms83's Avatar
this seems like the next thing i keep running into that i need to buy.... ug.
