wheels help!!!!!
Old 06-21-2012, 12:08 PM
willy9's Avatar
Default wheels help!!!!!
Ok guy I have a question. Is +35 offset good or too much up front? And +25 offest too much or barely makes it in the rear?
Old 06-21-2012, 01:37 PM
willy9's Avatar
Anyone?
Old 06-21-2012, 06:53 PM
rbl3's Avatar
Ur offsets are off but it also depends on size of wheels. Check out the Wheel and Tire sticky
Old 06-21-2012, 07:37 PM
willy9's Avatar
They are 18x10 in rear xxr 521
Old 06-21-2012, 08:16 PM
VinR1's Avatar
35mm will work in front if the width is 9.5" or less
25mm on a 10" wheel will stick out past the quarters a half-inch or so
Old 06-22-2012, 10:14 AM
willy9's Avatar
What can I do to make them fit?
Old 06-22-2012, 12:01 PM
Skraight's Avatar
Narrow your rear end.
I am running 18x9.5 +30 and 18x10.5 +30 on my car and the rears stick out a little.
Old 06-22-2012, 03:45 PM
willy9's Avatar
Do you think narrowing is neceseray. I dont think they stickout that much.
Old 06-22-2012, 04:23 PM
carlos64030's Avatar
You already have the wheels on?
Old 06-22-2012, 06:49 PM
willy9's Avatar
No but I dont think they will stick out that much
Old 06-22-2012, 08:43 PM
VinR1's Avatar
Search for pics of 10.5" TTMs - theyre 44mm offset. Imagine them sticking out 19mm (little under an inch) more...
Old 06-26-2012, 02:34 PM
willy9's Avatar
I like that look
Old 06-28-2012, 12:24 PM
willy9's Avatar
Skraight, can you post pics plz?
Old 07-04-2012, 12:49 PM
willy9's Avatar
Bump for the day
Old 07-04-2012, 03:56 PM
hiram007's Avatar
I like that look
Wheels that stick out past the fender is not a good look, especially on camaros. You have 10's with a +25mm offset, not only would the wheel stick out but the wheel would be too narrow to fill in the well when you look at it from behind. The TTM's at 10.5 @ +44mm offer a plush with your fender set up and looks very nice at all angles (not the wheel but the set up), nice wide tire that doesn't stick out.
If you can't do anything about the wheels then I would try to get a narrow rear or look to trade the wheels for a different size
Old 07-05-2012, 12:16 AM
willy9's Avatar
Its on a ws6, about how much would I need to narrow it? I also would like to get the rear 1/4 flared someone did it and it looks killer and he is running like 19X14 wheels on stock size rear end.
Old 07-05-2012, 08:21 AM
hiram007's Avatar
Probably about half an inch. The guy you are referring to with the flares, I followed his thread for a while. Although I am not a fan of flares on a WS6, the way he went about it was VERY VERY CLEAN. He didnt cut any corners and it took him a long time to do it and get it right. I have no information on his wheels but I am sure to get those 19's to fit he had to do something about the offset and wheel well (as shown in his pics). TT2's already stick out about a half inch and they are 11's, imagine 14's.
That guy has the first legit set up I've seen. But he did ALOT OF WORK to get it to look that way. Didnt just draw it up on a piece of napkin and go for it. I would do my homework on what all was involved before going that direction.
Old 07-05-2012, 01:24 PM
willy9's Avatar
Yeah but I live in tx abd U can just take it to the same shop
Old 07-05-2012, 02:23 PM
First of all, you need to decide what you're going to do. If you're going to flare your fenders like Austin's car, then there's no need to shorten your axles.
Old 07-05-2012, 03:21 PM
hiram007's Avatar
Exactly.
This was a one off deal. I dont know of too many shops willing to do something like this without some consent from the owner that if something goes wrong, they are not responsible. Needless to say, this is not your run of the mill mod.
Quick Reply: wheels help!!!!!
