dermot
06-22-2012, 03:53 AM
Hi,
Searched threads but didn't see anything like this.. my car (2000 TA manual with 130k miles & a few mods) has been fine, I've owned it several years, but then recently it has started sometimes giving all the symptoms that in a carb car, I would say were "fuel starvation". BUT it does not do it all the time, and never when I first start it, only after it's been running a while (more than 30 mins usually). The symptoms can come and go again during the same journey. So it isn't something like the filter (which I changed 6 months back anyway). Once it happens, it stays like that for quite a while, many minutes, perhaps an hour in a long journey.
It doesn't give any error codes, always starts, and behaves totally normally under about 1/3 throttle. Once you go above that, if the problem is present, it starts to feel really 'flat' & won't accellerate. But it doesn't seem to misfire.
The only thing I could imagine would be that the pump might be failing somehow(?) or in some way I'm getting low fuel pressure (haven't measured it, sorry..).
The thing that gets me is that it's intermittent?
Ideas? (I ordered a racetronics pump anyway, after 130k it seems fair..).
Thanks, D.
Thanks, D.
