harness re wire guy.....
Here is a picture of the one that I did for darren. I also have my harness, but I am not done with it yet. It is going to be a full control (engine/trans). With full intergration with my 1993 Mustang dash/chassis wiring.
Darrens was an engine only harness. I removed all the transmission control wires except VSS. I also left his O2 wires loose and unloomed because he was not sure if he was going to go with headers or manifolds. The harness was setup with a 4-wire style hook-up.
I know I am not a "board sponsor" but I am just a guy trying to keep his hobby moving with a little side work. I enjoy doing this stuff. I have a computer sciences degree, a very high level of electronics knowledge, and this stuff comes second nature to me....
Charles Ridinger
no, I sent instructions to wire up the relays as they should be. Remember, I only charged 150 to do it. If someone wanted that, it would be another 20-30 bucks to cover the parts.
Yes. Power (both igniton, and constant) ground, tach.
Also the TCC, and the fuel pump relay enable.
It also has an OBD2 plug and a CEL.
i was happy with his work. he kept in contact with me through the process. my harness needed a little more work due to the hack job from the junk yard. he sent an instruction sheet with mine.
