What will it run?
Old 06-25-2012, 10:44 PM
Blue/GreenT/A's Avatar
Default What will it run?
With the mods in my signature, what do you think I'll run? Last trip out before longtubes and stall i was running 13.0xx at 110,xx mph with horrible 2.2+ 60' times. I plan on going to the track in the next few weeks. I'll be running on 245/50/16 Nitto 555r's on salad shooters.
Old 06-28-2012, 09:34 AM
blk/slvr02ss's Avatar
Should be high 11's if you hook up !!!
Old 06-28-2012, 01:58 PM
Jarred Hodges's Avatar
should be high 11's if you hook. I run the exact same tire and they like a good burnout even on a basically stock car
Old 06-28-2012, 11:28 PM
superGTO's Avatar
Should be close. It will all depend on your 60 ft getting hooked.
Old 06-29-2012, 09:15 PM
That's about what I was thinking, I'm going to the track the 13th. I'll let you know how it goes. Thanks for the replies
Old 06-29-2012, 11:23 PM
nmass399's Avatar
Has the car been tuned with the new setup?
Old 06-29-2012, 11:47 PM
Yes it has, it's running pretty good right now on the street anways. I've only gotten on it hard twice since the install but everything seems to be working well. I don't know about dyno numbers, the last dyno made 348rwhp and that was before gears, stall and LT's with the catless y pipe.
Old 06-30-2012, 01:50 AM
nmass399's Avatar
Sounds good then, i am not sure if it will dip into the 11's but no doubt it will pick up a good bit. I would like to say it will run around a 12.1 but maybe it will be faster.
Quick Reply: What will it run?
