Need a clutch after Maggie install. LS6 Intake, TB, MAF, Misc parts
Category: Engine - Intake/Fuel
Price: $0
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO
Location (State): MS
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
Opens to offers, but not insults.
SLP LS6 Intake: Keeps EGR, or do like me and move the IAT to here and run a custom intake. MAP sensor needs rubber gasket, no throttle cable bracket. Might need new EGR o-ring. ~10,000 mileS: $425
With TB, $450
**SOLD** Fuel Rails and injectors alone: $50 **SOLD**
TB alone. TB is slightly ported. Blade has a slight knife edge ~50,000 miles No sensors: $50
**SOLD** Stock LS1 MAF sensor. Center air dividers completely removed: $30 **SOLD**
GTO Magnacharger reservoir tank, battry mounted:$35
GTO Magnacharger intake elbow. Accordian piece damaged: $25
**SOLD** LS6 valley cover with LS1 to LS6 PCV Valve and hoses. ~4000 miles: $50 **SOLD**
4.5" to 4" silicone reducer: $5
Magnacharger 4" coupler: $1
Magnacharger 4" outer spacer?: $1
Pair 4" T-bolt stainless clamps: $1
Pair 3.5"? Magnacharger clamps: $1
Stock 3.2" Magnacharger pulley. ~500 miles: $20
Stock Magnacharger gates belt. ~500 miles: $10
LS6 crossover tube: $25
Crank pin kit, will need new pins: $40
3-bolt to 4-bolt TB adapter Hole is 78mm, could be bored to 90mm: $25
Siliconeintakes.com Bosche(Maggie) coolant pump mount: $3
Superchargered by Magnacharger Tag plate: $5
Unused K&N filter for LS1 GTO: $25
**SOLD** OEM LS1 tensioner. ~50,000 miles: $15 **SOLD**
LS6 Yellow Springs. ~5000 miles: $40
Brand new LS1 Plastic tank fuel level sender: $30
Brand new OEM fuel pump from OEM fuel pump module. With both socks: $30
Used and damaged fuel pump module. From 2000 Z28 with 50,000 miles. Somehow worked fine in my swap aside from fuel gauge. Found damage from the donor car's wreck when swapping in Racetronix pump. Hence why I have a new sender and pump above. Had to buy a whole new unit. Good for used OEM pump, or bucket modifications. $25
All plus shipping from 39402. Cheaper stuff can be thrown in with other parts ordered for free. Ebay ID: MS-Fbodies
Kevin D.
