I was just thinking
Old 06-27-2012, 11:09 PM
lt4388stroker's Avatar
Default I was just thinking
Why doesn't F.A.S.T make a plastic Lt1 or lt4 intake for us, I mean there isnt a real aftermarket intake for us they could make a killing I think. Someone should suggest it to them lol
Old 06-27-2012, 11:57 PM
robsquikz28's Avatar
because ltx are lame and waste of $
Old 06-28-2012, 12:36 AM
Puck's Avatar
AFR makes a composite SBC single plane that I thought about getting, but it would be big money to port and set up to match my maxed out supervic that wouldn't really be justified.
Since I imagine you cant drill on its base to convert it, you would need to have your heads converted to SBC bolt pattern.
Wouldn't be financially feasible to invest in an LT1 composite intake since ours is good enough for most cars, and those who need more usually just convert an SBC intake.
Old 06-28-2012, 12:40 AM
Yea we are def the black sheep lol
Yea true.. but it wuld be nice to run a 102tb like the ls's and have something light weight ya know
Old 06-28-2012, 12:55 AM
ya well not for us. Thats why we have to convert to sbc intakes or run what we brung! lol
Old 06-28-2012, 09:27 AM
fex77k's Avatar
Very little chance that any company would invest in new LT1 specific castings. After the aftermarket block fell through it keeps the LT1 rather limited in the displacement category.
Old 06-28-2012, 09:38 AM
speed_demon24's Avatar
You really expect a company to invest a few hundred thousand dollars in r&d and molds into an intake manifold that they would be lucky to sell 100 of?
Old 06-28-2012, 11:02 AM
guy can dream lol
Hhmm yea lol.. Thats the purpose of a company to take risk lol im sure they.can afford it with all the lsx they are selling
Old 06-28-2012, 12:22 PM
Puck's Avatar
The LT1 community is bigger then ls1tech.com.
Edlebrocks intake is trash and I'm sure they have sold thousands of them. One actually worth something would surely sell a lot. Its an easy mod that even the bolt on crowd who don't like digging into their engines would do, and sadly if it just looks cool under the hood people will buy it whether or not it performs.
Old 06-28-2012, 12:36 PM
exactly what i was thinking something that looked cool and performed would def sell i think
Old 06-28-2012, 01:11 PM
96capricemgr's Avatar
The Edelbrock sells because it has a NAME that has been a part of hotrodding as long as the smallblock Chevy has been around or actually longer I believe.
Few years ago a guy was all gunho on this promising a prototype and all and the project seems to have disappeared.
You can epoxy or coat your intake to keep the charge cooler.
IMO the biggest hurdle is the lack of clearance offered by the f-body. Lingenfelter was selling modified Accel super ram intakes for the b-bodies, a company called I think First Fuel Injection here in Wisconsin makes a LT1 TPI style intake again been used on some b-bodies.
In the end though I think Lingenfelter himself summed it up well when he said something about how the stock intake works better than it should. So in the end most of this intake swap stuff is all benchracing. Several of the guys who have done the gen 1 intake swaps have openly regretted it.
Old 06-28-2012, 03:06 PM
Fly on the wall's Avatar
This was from Lingenfelter himself:
"It's apparent that the LT1 intake was seriously limited in its design by the Camaro and Firebird styling to the extent that Chevrolet engine designers were not allowed the freedom to create the manifold they perhaps would have preferred."
That was from his book published back in '96. Who knows what kind of intake LT1s would have received if the designers were not so 'limited'.
Old 06-28-2012, 03:15 PM
RamAir95TA's Avatar
I wouldn't call 500-600fwhp through a stock intake "limited," per se, even if it came from Mr. Lingenfelter's book.
Old 06-28-2012, 03:29 PM
LT1 intakes, with healthy camshafts, have poor fuel distribution at low/mid rpms. They would be much better served with an LS style intake. But I know, woulda/coulda/shoulda.
Old 06-28-2012, 03:40 PM
ahritchie's Avatar
IMO, it's the heat soak issue that's the bigger downside (along with the much heavier weight of it). My LS car is much less negatively affected by hot summer driving/idling than the LT1 is.
Try holding your hand on a LS intake vs a LT intake after 100 miles driving...lol
Old 06-28-2012, 03:46 PM
Yeah, that **** does get hot.
Old 06-28-2012, 03:59 PM
someone should start making them then lol cooler airflow is always better for a engine than the hot *** ones we got
Old 06-28-2012, 04:23 PM
Coatings can help with the heat thing.
Far as the Lingenfelter quote that supports what I said about the f-body being the limiting factor but if you dig around you will find a quote by him about how it still does work "better than it should" Not that you want to see a quote like that because a blind wish for someplace to misspend money is all most guys want.
Old 06-28-2012, 07:44 PM
englundjd's Avatar
well if intake air temps are so hot and a plastic intake like the lsx cars have would help keep the heat soak down then why not just make a plastic version of the ltx intake? that would probably be easy to make, wouldnt break the bank and would prolly gain us some horsepower.... or am i just crazy?
Old 06-28-2012, 08:06 PM
trilkb's Avatar
Your just crazy
LTX BOOOOO...LSX YAAAAAAYYYYY
Thats about the easiest way to put it lol.
Quick Reply: I was just thinking
