I think I'm having valve float help!
I have a forged bottom end with 232/236 114lsa and .615 lift cam with patriot ls6 heads when my car got to 5800 Rpms on the dyno it isntantly stoped making power.
It's got ls7 lifters comp gold 1.7 rockers hardened pushrods and it has dual spring from
The previous owner if I had to guess there probably patriot (patriot heads) it's the only used thing I used when I built this motor besides the crank . I'll post the dyno graph in a little basically climbs to 400hp as Soon as it hits 5800rpm it levels out and the line is al squiggly lol
why would i switch back to stock rockers? I had stock ones on there when it was dyno. then i put roller rockers on because the bearings were going and its exactly the same just quieter
Normally when you have valve float there's a dip at the top end and then it nose dives off. It doesn't appear that yours is doing that. However your tq curve seems to be a little wavy. The local machine shop set my heads up wrong and I had horrible valve float. My dyno graph was really jagged and then dropped off.
