I think I'm having valve float help!
Old Jun 28, 2012 | 05:39 PM
Luke1834's Avatar
Default I think I'm having valve float help!
I have a forged bottom end with 232/236 114lsa and .615 lift cam with patriot ls6 heads when my car got to 5800 Rpms on the dyno it isntantly stoped making power.
Old Jun 28, 2012 | 06:30 PM
Darkman's Avatar
Describe the rest of the valvetrain - i.e. what valve springs, rockers, etc.
Old Jun 28, 2012 | 07:47 PM
Luke1834's Avatar
It's got ls7 lifters comp gold 1.7 rockers hardened pushrods and it has dual spring from
The previous owner if I had to guess there probably patriot (patriot heads) it's the only used thing I used when I built this motor besides the crank . I'll post the dyno graph in a little basically climbs to 400hp as Soon as it hits 5800rpm it levels out and the line is al squiggly lol
Old Jun 28, 2012 | 07:55 PM
outkast6991's Avatar
Easiest first step would be to switch back to stock rockers. After that I'd pull a couple springs and check pressures
Old Jun 28, 2012 | 08:10 PM
Luke1834's Avatar
why would i switch back to stock rockers? I had stock ones on there when it was dyno. then i put roller rockers on because the bearings were going and its exactly the same just quieter
Old Jun 28, 2012 | 08:35 PM
Didn't know you had the float on stockers. Aftermarket rockers are known to be heavy over the nose which will induce float. Guess its time to pull some springs
Old Jun 28, 2012 | 09:44 PM
Luke1834's Avatar
what new springs would you guys recommend this cam should make power to 6500 rpms and with the forged bottom end i wanna take it that high .
Old Jun 28, 2012 | 09:47 PM
Call PAC and give them your cam specs. They can get you a quality spring with the pressure you need
Old Jun 28, 2012 | 11:51 PM
Havoc40's Avatar
Springs or lifters. Maybe a combo of both.
Old Jun 29, 2012 | 09:14 AM
Luke1834's Avatar
The lifters are like new only have maybe 200 miles on them
Old Jun 29, 2012 | 10:15 AM
KRAZY K 2000 TA's Avatar
Fuel pressure at WOT? Injector size?
Old Jun 29, 2012 | 10:19 AM
TurboBuick6's Avatar
A very erratic power band is valve float 90% of the time.
Old Jun 29, 2012 | 10:39 AM
Luke1834's Avatar
It has 30lb injectors , what does erratic power band mean ?
Old Jun 29, 2012 | 11:01 AM
Your power band line on the dyno gets very jagged just befor you lose your power.
Old Jun 29, 2012 | 02:15 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
I'm guessing you need new springs, AND shimmed to within .050 of coil bind.
Old Jun 29, 2012 | 02:39 PM
Luke1834's Avatar
I think I'm just gunna get some new springs the valvtrain seems a tiny bit noisy also
Old Jun 29, 2012 | 04:55 PM
Luke1834's Avatar
that is the dyne 5 days before i switched to turbo 400
Old Jun 29, 2012 | 11:27 PM
Luke1834's Avatar
Posted dyno graph please tell if it looks ok ?
Old Jul 1, 2012 | 02:02 PM
LilJayV10's Avatar
This. I was going to ask what your spring height is set at.
Old Jul 1, 2012 | 02:03 PM
LilJayV10's Avatar
Normally when you have valve float there's a dip at the top end and then it nose dives off. It doesn't appear that yours is doing that. However your tq curve seems to be a little wavy. The local machine shop set my heads up wrong and I had horrible valve float. My dyno graph was really jagged and then dropped off.
