Generation IV Internal Engine - 6.0L ls3 heads (which gaskets?)
View Full Version : 6.0L ls3 heads (which gaskets?)
flynlow3
07-01-2012, 11:32 PM
I have searched with no definate answer. Can someone tell me which gaskets I will need to use?
I have a 6.0L iron block that is bored .30 over and a brand new set of ls3 heads. I will be assembling as soon as I get it back from the balancing shop and need to know which head gaskets to run. Also,
I plan to go with ARP head bolts. Which set? Can someone point me in the direction of a part number?
Please and thank you!
zummo
07-01-2012, 11:49 PM
I would use lsa-ls9 gaskets if it was mine, Here is the lsa-ls9 gasket part# 12622033 if you want it. If you are gonna boost it or spray it.
1badeagle
07-01-2012, 11:56 PM
I used stock ls3 gaskets from scoggin dickey
Gray86hatch
07-02-2012, 08:10 AM
I used 6.0 ls2 headgaskets.
Tim
3pedals
07-02-2012, 04:33 PM
I used 4.00 x .040" cometics
Scoggin Dickey
07-02-2012, 04:40 PM
Use LS3 gaskets. As for the bolts, what year is the block? It's fairly assumable that it's the old style block and needs ARP 134-3609.
