LT1 5.3 in C3 corvette info needed
I am putting a 2002 LT1 5.3 motor in a 1979 corvette i need a bit of advise
where can i get an oil pan and pick up for use in a car
what would be the right choice for camshaft
what intakes will work fuel injected that is and where can i source these
bought the engine with harness ECM , what tune would work best
and all accys includeing the AC pump can i use this in the car with the stock evaprators ect.
paid $650. 00 for it all was running when pulled 85,000 miles
hope it was a good deal
I guess thats what it is hell chevy has so many LT 1 2 3 4 LS 1 2 3 4 5 6 LQ????????? ect ect Gen 1-2-3-4-5 who knows. came out of a 2002 Taho has aluminum heads and says vortec on the intake cover You tell me I just want to put it in a 79 Vette
Probably an LM7.
What accessories, PS, AC?
What trans are you hooking it to?
Is it cable TB or DBW?
Which ecu, 411?
Might get you started;
https://ls1tech.com/forums/conversio...eed-build.html
Which ecu, 411?
Oil pan. 98-02 F body, corvette seem to work well. I used a batwing. Check classified here, craigslist, ebay. Got mine for $100 with pickup, windage tray on ebay.
Stock cam is fine to start. Anything more than an LS1/6 will probably need a custom tune.
LS1,6 intake will fit under the vette hood and you can reuse your TB and injectors. Got mine locally, craigslist $35 with rail.
Start with stock tune, VATS, emission removed.
98-02 F body or corvette PS/alt will fit in a vette but you'll also need to change out the water pump and balancer.
Kwik makes a PS/alt bracket that fits in corvette, f body or truck spacing.
Kwik also makes a sanden compressor mount in all 3 spacings.
I am not sure looking for a 7oors but wouildnt mind someithing in a 5 or 6 speed auto or manual just in the planning stages
any suggestions ???? rear end will be stock not looking to overpower anyone
Check the Pistons to see if you got a 5.3 or 4.8. If they are flat top it is a 4.8. You can take out a spark plug and shine in a good flash light. Reason I say this is cause i know a few people who got a 4.8 when they thought they got a 5.3. The 5.3 pistons look like this:
http://nelsonperformance.com/ Best place for tune in my opinion!
P.S. If it is a 2002 engine then it is not a LT1, so don't look for LT1 parts they are not interchangeable. It will be a GEN III LS engine like a 5.3 LM7 or a 4.8 LR4. The 5.3 and 4.8 will have a raised marking on the driver side front of the engine that will say 4.8/5.3 because they are the same block but different bore and stroke.
