PIcked up OEM C6 Chrome five spokes 18x8.5 19x10
Just grabbed an oem set with tires on ebay. Question is what type of lug nut do I need? I know its 12mmx1.5 but as far as the seat type acorn conical or flat, what are they? I cant seem to find that answer with my searches.
And I already ordered the adapter spacers for the rear two.
Thanks for the help.
The seat refers the exterior design of the lugnut. The size is all that matters, 12mmX1.5 in this case. You can put on whatever you want depending on preference. Some look better on some rims than others.
Look at the seats on the wheel. If they are tapered, use a conical seat lug nut. If they are flat, then use flat. They are not only designed to keep the wheel pulled onto the hub, but also to keep it centered on the axle. Most flat design lug nuts have a straight shank that goes inside the holes of the wheel to center it, as well as a built in flat washer area to distribute the load. Conical seats obviously use their shape to taper fit into the wheel to center it up. Use the right stuff instead of just throwing some **** together that can damage your wheels and possibly fail and cause an accident or something like that. In my case, my wheels require conical seat nuts. I picked up some Gorilla 1/2 x 20's at a local auto parts store. They also had a few other common sizes so it shouldnt be hard to find some that will work properly.
Yes, I will use what is proper. I just wanted someone with the wheels to tell me what seat they are so I could order the lugs and have them here when the wheels arrive. I figured with all the guys here running C6 wheels someone would remember, but maybe they just haven't been in the thread yet.
