Generation IV Internal Engine - Thermostat interchanability
Jeep09
07-09-2012, 11:24 PM
Does anyone know if Stant makes a 180 or slightly less thermostat for the LS1? iIseen one on EBAY PN -14698 but its sounds sketchy if its a fit.
stevieturbo
07-22-2012, 05:59 PM
You can get 160DegF stat for an LS1. The stat is integral to the housing. They arent overly cheap though.
http://www.evo-host.co.uk/getimg/29435.jpg
http://www.evo-host.co.uk/getimg/29436.jpg
S10xGN
07-22-2012, 08:35 PM
The integral housing one? You can disassemble it and stack a few shims under the shaft. IIRC, I used two 3/16" pop rivet washers and ended up at 170°...
Jeep09
07-24-2012, 12:40 AM
Thanx, will give it a try
S10xGN
07-24-2012, 07:41 PM
This thread (http://ls1tech.com/forums/generation-iii-internal-engine/1567745-ls1-180-t-stat-what-should-my-temp.html) will help. He used pieces of rod inside the hole, I used shims (small washers) over the rod. Just a different method of accomplishing the same thing...
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
