Cam swap and Air/Fuel Ratio....
Old 04-02-2004, 07:53 AM
AdamSS's Avatar
Question Cam swap and Air/Fuel Ratio....
From what I have researched, changing a cam will mess up A/F ratio a little bit. How much will it change if I go from stock to 224/224 LSA 112 type of cam.
Will A/F change by not more than +/- 2% ??? Does anyone know before and after numbers ?
The reason I'm asking is to know if with Predator I could do a basic tune (Predator allows a maximum 2% change in A/F ratio)
I figure this, plus higher idle set, and raised rev limiter will make a good tune for that cam...
Any input would be greatly appreciated
Thanks
Adam
Old 04-02-2004, 08:12 AM
PSJ Wannabe & Attention Whore
BOO HOO BRIAN's Avatar
After a cam swap the only way to tune is with an edit program. There are so many variables from car to car its hard to say if 2% will work.
Quick Reply: Cam swap and Air/Fuel Ratio....
