Cam swap and Air/Fuel Ratio....
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
From what I have researched, changing a cam will mess up A/F ratio a little bit. How much will it change if I go from stock to 224/224 LSA 112 type of cam.
Will A/F change by not more than +/- 2% ??? Does anyone know before and after numbers ?
The reason I'm asking is to know if with Predator I could do a basic tune (Predator allows a maximum 2% change in A/F ratio)
I figure this, plus higher idle set, and raised rev limiter will make a good tune for that cam...
Any input would be greatly appreciated
Thanks
Adam
Thanks
Adam
