Fueling & Injection - racetronix fuel pump
spiro27
07-15-2012, 04:43 PM
my 01 trans am has 226-234 cam tfs 215 heads 1.7 yellateras long tbe headders 1/78 and 42lb racetrnics injectors fast 92 intake and tb . just finished putting it all together ans was tols i should do fuel pump before tunning. looking at the ractronix fuel pump at ws6 store what do you guys think of it and im gooing with hotwire kit upgraded ground not shure about booster. how many versions arew there of the racetronix in tank fuel pump for trans ams.
http://www.ws6project.com/user_stor/catalog/99-02-ls1-f-body-plastic-racetronix-fuel-system/
thanks for help not looking forward to taking tank down and dont wana cut my floor.
spiro27
07-15-2012, 06:27 PM
I am running stock fuel rail and regulator. Will I need a new fuel pressure regulator with a new fuel pump. Will I need to cut or crimp any wires for the fuel pump install.
TransamGCS
07-17-2012, 07:09 PM
racetronix with hotwire kit is the way to go dont have to cut or crimp wires very easy instructions just make sure you have the two sock filters my racetronix kit came with them but some dont i got mine from ws6 store might as well replace the regulator while you have every thing apart
devic
07-18-2012, 07:42 AM
dude do not get the racetronix hot wire kit its a rp off, get the casper same thing for 35
the racetronix kit is 75
Ollie8974
07-18-2012, 10:27 AM
That is the correct pump for the 01. The jet nipple is clearly shown in the photo. Some vendors will say they offer the correct pump, but they are not.
With out the jet pump the fuel pump will not operate correctly.
Black_Thunder_00WS6
07-18-2012, 10:55 AM
I am running the same Racetronix pump with the hotwire kit, also purchased from WS6store. Works great! Pretty easy install too, as long as you don't have a full tank of gas... Good Luck!
TransAmcoupe98
07-18-2012, 11:23 AM
Racetronix is good shit. Ive had 3 racetronix kits, and easy to install compared to others.
spiro27
07-18-2012, 06:15 PM
Do I need to change the regulator on the fuel rail. Or am I okay to just put fuel pump kit in and it be okay.
spiro27
07-20-2012, 04:16 PM
does anyone know if i need to change the in take regulator? or have a write up on how to change it. it it nessisary for my setup how much i t costs. will my stock fuel rails be okay for all of this with new pump. thanks for help.
Ollie8974
07-21-2012, 09:03 AM
The 01 regulator is in the fuel pump module in the tank not on the fuel rail. No you do not need to change it.
spiro27
07-22-2012, 01:07 AM
thanks for help im gona put a fuel pressure sensor on it while its out. should i put regulator in it just for cheep insureance. do the in tank regulators have any problems usually.
ls1wallen
07-22-2012, 01:16 AM
you can get a new regulator from rockauto pretty cheap if you want to play it save while your in there
spiro27
07-22-2012, 01:27 AM
the stock one would be fine for my setup. does anyone have the part nuber for it. think im gona do fuel level sensor too and fuel pressure sensor. ijust wana do it all one time. taking diff out goin through all the work to take tank out i dont wana ever go in there again.
spiro27
08-14-2012, 11:08 PM
with the racetronixs pump what should the fuel pressure be at key on and running.
spiro27
08-14-2012, 11:23 PM
im getting 50 psi key on is that good.
spiro27
08-15-2012, 05:46 AM
i have 49 psi key on engine off. 61ps1 engine running. when i rev it up its stays the same and when i release throttle.
