Gears & Axles - 3 channel on a 9"
View Full Version : 3 channel on a 9"
superman2002
07-18-2012, 09:52 PM
i am looking to buy used moser 9" or a used moser m9 the problem niether have the abs sensors what would i need to do install it my car has a 3 channel set up and can i use any of the parts off my 10 bolt:cheers:
superman2002
07-19-2012, 01:19 PM
Bump......n
superman2002
07-21-2012, 09:02 PM
nobody
Bob@BruteSpeed
07-23-2012, 05:36 AM
The easiest thing to do is to go ahead and install the rear and just not hook up the ABS. If you don't hook up the ABS on the rear, the front ABS won't work either. Basically you would be back to old school brakes. You will have the ABS light staring at you on the dash, which cannot be tuned out. You can pull the bulb or paint the bulb black, etc. To install ABS on the rear would entail setting up the center section with the exciter ring, and drilling a hole through the top of the housing where the pick up goes. I would not recommend trying to do this. Bob
ssvert99
07-23-2012, 09:25 AM
MWC was the first to offer 3ch on production 9 inch rearends and now can retrofit any 9 inch rearend for the 93-02 f-body 3ch ABS system. Give us a call.
superman2002
07-25-2012, 08:46 PM
thanks guys for your input i think i may just buy a new one to get everything i want :)
bwilde86
07-25-2012, 09:12 PM
how can you tell if your car is 3ch or 4channel?
superman2002
07-26-2012, 07:37 PM
3 channel has a sensor on the pumpkin 4 channel has 2 sensors one on each axel
2QuikTA
07-27-2012, 06:01 PM
4 channel has TC
