New build issues
New build issues
I just got my ECU back from my mail order tune, and was able to start my car for the first time. It sounds like it is running fine, but fuel is coming from my tail pipes. I'm running 36lb @ 58 psi injectors, stock MAF, MS3, 243, LT, lid, LS7 coils. I have no check engine lights, and all the EGR and emission stuff has been removed. Any ideas? I want to fix this issue so I can break it in....
Hook up a fuel pressure gauge to the rail, see if it holds pressure after you shut down the engine. If it drops straight to zero it's possible you have an injector stuck open.
Were the injectors new or used?
LS1Tech Premium Sponsor
Glad to hear that was it, Brian (well, sucks you have a bad injector, but glad it's not the tune)!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Nice catch bro. It could have been catastrophic, had the injector puddled the cylinder.
