who makes this crank?
Old 07-27-2012, 12:48 AM
baggins's Avatar
Default who makes this crank?
And any ideas what model
I am thinking its a Lunati but not sure-
Old 07-27-2012, 11:23 AM
baggins's Avatar
Anyone?
Old 07-28-2012, 12:23 AM
baggins's Avatar
Need some help guys
Old 07-28-2012, 12:32 PM
Monzsta's Avatar
Got an old engine block you can set it in?
Or take a couple 2X6's and hack some notches in it so you can spin the crankshaft. kinda like this.
Take a coat hanger and cut it and make a hook for one of the rod journals. Lay the long part of the coat hanger on the bench. Or the block edge.
Spin the crankshaft untill the coat hanger stops moving in one direction. Mark it with a felt tip marker.
Spin the crank 180 degrees, 'till it stops moving again. Again, mark the coat hanger. The distance between your marks will be your stroke.
Have a beer.
Old 08-03-2012, 12:25 AM
baggins's Avatar
Do cranks not get a part number to identify them?
Old 08-09-2012, 03:36 PM
baggins's Avatar
Anybody???
Old 08-09-2012, 04:45 PM
KCS
Moderator
KCS's Avatar
I'm thinking it's Lunati as well. They are the only crank manufacturer I can recall that does a radius where they drill, like on that first counterweight.
Old 08-09-2012, 07:45 PM
v8pwr's Avatar
That looks like a pretty nice crank but I don't know who makes it. I don't think it's a Lunati as they stamp the part # on the first counterweight. I also don't remember Lunati stamping the bobweight but the machine shop could have done that. Whoever did it cared enough to do it straight.
Old 08-09-2012, 08:52 PM
baggins's Avatar
I called lunati today and they verified that it is theirs.... used in 1500+ HP applications. Ill be using this along with my linati billet I beams and diamond pistons in a 403ish stroker- should make 1000 easy!
Old 08-09-2012, 08:58 PM
LS6427's Avatar
Should handle 1,000 hp........will it make that much???? Depends on whats ramming air down the engines throat.........
Old 08-10-2012, 02:11 AM
baggins's Avatar
Either a s480 or twin 62s
Old 08-13-2012, 01:18 PM
Mike454SS's Avatar
Certainly looks like a nice piece.
Old 08-14-2012, 03:49 PM
baggins's Avatar
Thanks... can't wait to get the motor together
