Fueling & Injection - Fuel pump trap door
kunkelz28
07-31-2012, 09:58 AM
i have done the fuel pump trap door before on my 94 z28, i will be doing this again on my 99 Camaro SS. Do i cut i the same place as my 94z28? or is the pump on the LS1 cars more forward or back? any help would be greatly appreciated. thank you!
I8UR4RD
07-31-2012, 10:20 AM
:search:
wilson34
08-04-2012, 10:37 PM
^^ Way to help there bud.
On my 2001, the sending unit was located towards the back. The panel I made extended directly up to where the panel slopes down toward the rear of the car.
oldmano2z
08-04-2012, 11:23 PM
from what i've seen on here i think it might be the same. but i don't think it is as far back as you stated . when mine goes i'll be cutting and using a piano hinge on one side,to make it a trap door.
99Bluz28
08-04-2012, 11:46 PM
Just did a search for "Fuel pump trap door" . :thumb:
http://ls1tech.com/forums/generation-iii-external-engine/1531302-please-quick-help-trap-door-method-3.html
javier1730
08-05-2012, 12:25 AM
i can take pics of mine tomorrow so you have an idea.
01ssreda4
08-05-2012, 04:03 AM
3 cuts, peel it back, do the business, fold it back into place, drill two holes, rivet two small pieces of metal (that will swivel for future access) and seal with some type of tape. You can use the factory indentions as cutting guides. Cut just to the inside of them. See here:
http://i275.photobucket.com/albums/jj294/01ssreda4/Trapdoor2.jpg
http://i275.photobucket.com/albums/jj294/01ssreda4/Trapdoor1.jpg
kunkelz28
08-07-2012, 02:18 AM
you guys rock! Thanks. Well I got my new pump in and well after some nice 4 letter words i fished my new wire hairness thru, no dropping the tank for me
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
