LSX Family Injector Flow Rate
Hi, I would like to confirm this information,
LS1, 29lb/hr@58psi, GM # 12561462
LS2, 34lb/hr@58psi, GM # 12569113
LY6, 30lb/hr@58psi, GM # 12580681
LS3, 41lb/hr@58psi, GM # ????????
LS7, 42lb/hr@58psi, GM # 12576341
LS9, 48lb/hr@58psi, GM # ????????
please modify and add new info
Regards
Raul
Regards
Raul
Regards
Raul
Regards
Raul
Ls1 99,2000 26.6@58 0280155890 26.8@58
LS1, ls6, 29lb/hr@58psi, GM # 12561462. 0280155931. 28.8@58
LS2, 34lb/hr@58psi, GM # 12569113 0280158049. 34 @58
LY6, 30lb/hr@58psi, GM # 12580681. Delco 217-1621 30@58
LS3, 41lb/hr@58psi, GM # ???????? 0280158051. 42@58
LS7, 42lb/hr@58psi, GM # 12576341. 0280158051. (ls3,ls7 use same injector)
LS9, 48lb/hr@58psi, GM # ???????? 0280158187 59 @58
Lsa. Same as ls9
It's an oem injector so Bosch does not have it listed on their global sheet yet, however, on a flow bench they flow approx 59 @58psi there is all kind of spdata floating around on these. This is what I get.
I'll use the Bosch#.
Lsa. Same as ls9
Lsa. Same as ls9
Regards
Raul
Regards
Raul
Great info!
Is there a spec / guide chart as to what "horsepower rating" each injector set is capable of handling?
It seems like alot of guys are trying to go way to big on injector sizing, jut like the old school guys used to try and put huge carbs on small blocks and wonder why they weren't performing as well (ie. 850cfm vs 650cfm)
I feel that would be helpful to alot of members
Thanks, Jeff
Raul,
Great info!
Thanks, Jeff
Great info!
Thanks, Jeff
Well a HP rating would vary based off BSFC (Brake Specific Fuel Consumption) so Displacement, and weather or not Forced induction is involved would make a difference. But there are at least a dozen injector calculators on the internet made available by just about every injector / fuel pump company.
# GM # Bosch Max HP Conn Style
LS1* 26,6 12555894 26,8 ?????????? 340 Mini EV1
LS1 28,5 12561462 28,8 280155931 365 Mini EV1
LS6 29 12561462 ?? ?????????? 371 Mini EV1
LS2 34 12569113 34 280158049 435 Uscar EV6
LY6 30 12580681 30 Delco217-1621 384 Uscar EV6
LS3 42 12576341 42 280158051 538 Uscar EV6
LS7 42 12576341 42 280158051 538 Uscar EV6
LS9 48 ????????? 59 280158187 614 Uscar EV6
LSA 48 ????????? 59 280158187 614 Uscar EV6
Estimate HP with 80 cicle Duty and 0,5 BSFC.All at 58psi.
I have a number 280158051-85, that's a Bosch 85# injector,
that is sold by Fast as part # 30857, as an 85# injector.
But other cross references for this point at the GM part # for the LS3/LS7.
Maybe Bosch has two versions of it?
Trying to find the necessary info to put into HP Tuner for the 85# injector.
>>>Resurrecting<<<
LSA Fuel Injector PN 12598646 and everywhere I look they are 52lb./hr at 58psi Fuel pressure
http://paceperformance.com/i-6220144...-injector.html
LSA Fuel Injector PN 12598646 52lb./hr at 58psi Fuel pressure
Summit and GM Parts direct also carry this injector. Around $50 each
https://www.summitracing.com/parts/ado-217-3350
https://www.gmpartsdirect.com/oem-pa...ector-12598646
Another candidate is flex fuel injector from following engines LMG 5.3, LC9 5.3, L9H 6.2
12594512 36lb/hr@ 58psi. USCAR / EV6
Improvement over stock and readily available depending on the power needs.
https://www.psiconversion.com/tech/l..._injector.html good info here, very complete. I tried to attach an excel with this same info along with o ring spacing for the Gen 4 stuff. we'll see if the excel comes thru.
