LS1 sat for a year wierd compression when checked
Been lurking here for a while gathering info for my project. Love the site.
I recently picked up an 2001 ls1 and have been getting it ready to drop in. When I purchased the motor last week I was told it came out of a running car that was wrecked in the rear. I did a vin check and can see that it was salvaged almost one year ago next month. So it sat for a while drained of oil.
I did a compression check this morning after adding new oil and filter, and pouring some inside of the valve covers. With it still on the engine stand I also turned it over a few times by hand. My first compression check showed:
1) 120. 2) 180
3) 210. 4) 210
5) 210. 6) 60
7) 210. 8) 60
So I added a little oil to the cylinders and turned it over a few times and then let it sit for about 4 hours. When I rechecked it I got:
1) 150 2) 175
3) 195 4) 180
5) 190 6) 180
7) 180 8) 170
I checked the compression per the service manual, 4 cranks per cylinder. I recheked it 2 hours later with the same results as above.
My motor is still covered by the yards warranty and I wont be getting it running for a few more months, but I am at the stage where I am getting parts and having the ECU and wiring harness done. So Im not sure if the low compression was a result of sitting and being dry or I should take this one back and get another one?
I am very new to these motors so please excuse my lack of knowledge. I appreciate any insight you can provide.
1) 120. 2) 180
3) 210. 4) 210
5) 210. 6) 60
7) 210. 8) 60
1) 150 2) 175
3) 195 4) 180
5) 190 6) 180
7) 180 8) 170
Thank you for the input
I have checked a few more times since then and I'm getting a constant compression variation of 12% across all cylinders. Also I am only getting a difference of 6% at most between a dry wet compression check. Keep in mind this is on a cold motor.
I had it on a stand with a starter and battery hooked up. I ended up trading for a 20,000 fewer miles motor. I dont think the pressure should be 60psi even when cold. Especially when all other cylinders were hitting 180s.
Im not anywhere near a point to have it dropped in and didnt want to worry about it. I appreciate the help!
