95 hawk, door lock remotes not working right, Help
Old 08-05-2012, 12:38 PM
25thhawk's Avatar
Default 95 hawk, door lock remotes not working right, Help
I just replaced the batteries and reprogrammed the remotes. The remote works if I am sitting in the car, but from outside it will only work it the remote is touching the windshield. Is there a way to fix it? Where is the reciever inside the car and is there an antenna that might be unplugged or wire that might be in the wrong spot? Thanks
Ryan
Old 08-05-2012, 03:56 PM
Spartan7's Avatar
http://shbox.com/1/keyless_entry.jpg
Get a new remote. They only last so long.
Old 08-05-2012, 05:08 PM
25thhawk's Avatar
Ok, thanks. I don't know where Im gonna find a new remote. Gmpartsdirect doesnt have them.
Is there an antenna for the system? Im hoping it might be something like that.
Thanks
Ryan
Old 08-05-2012, 10:41 PM
shbox's Avatar
Thanks
Ryan
The antenna is inside the RKE receiver. The fact is, these old units just don't have the range of the more modern ones. Cold solder joints have also been known to affect them.
Old 08-05-2012, 10:45 PM
25thhawk's Avatar
Is there a way to make it work better? or should I just add an alarm with door locks?
I have 2 94's that dont have this same issue. I also have a 98, and I realize the newer system is much better. But the 94's operate well enough that it doesnt bother me. So if I could get it to work like them, I would be fine.
Thanks
Ryan
Old 08-05-2012, 10:48 PM
RJBAILEY84's Avatar
Im having the same problem. I got a new remote from eBay and programmed it myself, which was simple. However it only works when I'm right at the windows of my car. EBay sells the GM style remotes for 15 bucks of so. Mine works great other than having to be right at the car. I wonder if there's a way to install a 98+ year model security system on our cars without a lot of problems.. just a thought though
Old 08-06-2012, 08:19 AM
Spartan7's Avatar
I'm not a fan of the ebay ones. I got one for my truck, and the buttons always stick. I bought a GM one for the T/A a while back, and it worked great, even at distance. They're obviously more expensive, but worth it IMO.
Quick Reply: 95 hawk, door lock remotes not working right, Help
