95 hawk, door lock remotes not working right, Help
I just replaced the batteries and reprogrammed the remotes. The remote works if I am sitting in the car, but from outside it will only work it the remote is touching the windshield. Is there a way to fix it? Where is the reciever inside the car and is there an antenna that might be unplugged or wire that might be in the wrong spot? Thanks
Ryan
Ryan
The antenna is inside the RKE receiver. The fact is, these old units just don't have the range of the more modern ones. Cold solder joints have also been known to affect them.
Is there a way to make it work better? or should I just add an alarm with door locks?
I have 2 94's that dont have this same issue. I also have a 98, and I realize the newer system is much better. But the 94's operate well enough that it doesnt bother me. So if I could get it to work like them, I would be fine.
Thanks
Ryan
Thanks
Ryan
