LS4 Performance - Lost to a Camaro SS 6spd
View Full Version : Lost to a Camaro SS 6spd
Aaron Arceneaux
08-06-2012, 12:55 AM
My friends and I had some fun tonight in mexico...I had multiple runs from 15-100, 30-120, and 60-120....The only time I kept up was from the 30-70 then he would pull about 2 cars quick..He only said he has intake and straight pipes...Also ran a 335ci and beat him everytime except for the first run where I spun badly and over-revved...I took by two cars or more before I let off..We got up to about 140...what need to be done to beat the camaro if there is a solution besides my needing to retune.
gxp-miller-gxp
08-06-2012, 01:07 AM
i have raced a camaro z-28 with intake,tune,exhaust,headers and he would put anout 2 cars on me.
auto versus auto and both being stock,its a good race
but since he is a good driver you would need intake,tune,exhaust,shift kit, and probably a bit more.
when he shifts is your chance to catch up really so if you can shift as fast as possible it will defiantly help
Aaron Arceneaux
08-06-2012, 01:53 AM
I should have put more info...he is a 2011 camaro and I have crazyjoes old gxp...which has cai,headers,ls1 intake, and tune before the intake, I added shift kit with cooler...That is true when he shifted it gave me that tad bit of hope and then diminished as the taillights never got closer lol
DavidGXP
08-06-2012, 02:13 PM
3.69 gears with a camshaft would do the trick. If you can't afford a cam swap, then get some 1.8 roller rockers.
2nd and 3rd gear will always be sluggish due to the factory gearing.
3.69's will help a lot!
Aaron Arceneaux
08-06-2012, 02:22 PM
I've been saving for the 1.8rr...once the trans poops on me then I'll be going all out prob with tep guys...I think once i get tuned it should help too....and the 335ci wanted to race me for $200 from dig to 120 but I backed down since i haven't learned to launch without smoking the tires
DavidGXP
08-06-2012, 08:32 PM
For traction I recommend some sticky 275/40/18 summer tires on the stock wheels.
Weight transfer to the rear needs to be eleminated. If you are serious about traction, then contact Arraut Motorsports http://arrautmotorsports.com/grand-prix/ and have them build you a custom adjustable rear coil over kit. They offer adjustable shocks with stiffer coils which will help keep the front end planted. I also recommend ZZP front lower control arms http://shop.zzperformance.com/store/p/481-ZZP-Control-Arms-for-WBody.aspx The arms had problems in the past, but have since been fixed. The will prevent flex and maintain proper alignment/tire contact patch.
As hard as it is... Try to keep racing off of the streets:drive:
LS1 Racing
08-06-2012, 09:17 PM
What year Z28?
Aaron Arceneaux
08-06-2012, 09:33 PM
It is almost time for some tires I will look into that for sure, any brand preference on tires. This was in an area with very low traffic like two cars at most we saw...I want to keep traction but dont plan on making it a race car by any means especially with the low miles I plan on buying an el camino, s10 blazer or 70's model camaro to do an ls swap to beat on. I truly do appreciate the advice from you guys.
DavidGXP
08-06-2012, 10:44 PM
What year Z28?
2011 camaro
DavidGXP
08-06-2012, 10:46 PM
It is almost time for some tires I will look into that for sure, any brand preference on tires. I truly do appreciate the advice from you guys.
Hankook V12's:devil:
Aaron Arceneaux
08-06-2012, 10:53 PM
Intriguing lol
LS1 Racing
08-06-2012, 11:18 PM
2011 camaro
Ahh...You threw me for a minute..You raced an SS.. Last Z28 was 2002. :)
