blow thru carb guys cfm question
Well I got a 5.3 bored to 5.7 76mm turbo 20psi. I have a holley dp 650cfm carb. I've been 6.21@118mph 1/8th on bone stock 862 heads dual plane intake. I've recently had 862 heads ported polished w bigger 2.0 int ss valves installed. went from a dual plane to single plane intake and went from pump gas 93 to 115 race gas. I have went 6.18@119mph@best. motor does not seem to pull over 6k rpms no matter either setup. the only thing I have not changed is carb. Have I reached the 650 limit? or am I missing something?
What turbo? What's your AFR? A properly built 650 will support a ton of power if built properly. You may be out of turbo, valvespring etc. What exhaust? Have you checked back pressure? If your not going lean look somewhere else. Give as many details as you can on your setup.
On3 turbo..96a/r exhaust .80a/r cold. a/f is 12.2-12.4, 321 stainless 3" exhaust. How do you check back pressure? I have approx 3ft of exhaust pipe from turbo.I've got plenty of valvespring says my machinest. I done leak down test on motor sat. has 10-15% on every cyl. so its good internally.
3212 with me in it. what is the max of the 650? I really don't feel the turbo is maxed. I could be wrong. but I really don't think I'm any were near the 800hp rating of the turbo.
Depends how your 650 is set up. Single/Dual power valve are the boost referenced, what size PVCR's etc etc. Do you have vent tube extensions on it? I still say your turbo is done. It takes every bit of 800fwhp to go low 6's like you are at that weight. I never came close to maxing my old 650 so I can't really tell you how much they will support. Go to the blow through section on the turbo forums you may find more info there.
I have a single power valve. 3.0 non boost reference. rear pv is blocked off. I don't have vent tube extensions. I've seen guys at the track put fittings in from and rear fuel bowls as a balance tube. I thought about trying that. I don't have no way of monitoring egts.
Thanks for the tips guys. I got a guys c&s carb were going to throw on and see if it makes any changes. if not I will look into the turbo. The class I run has a 76mm turbo max limit and a cap of 5.70 I really need another 3tenths to really be good. I won the last race but if I don't get faster I won't be in the money. I got some strong competition coming soon. I wanna be ready. Will any 76mm turbo be capable of 5.70's?
Changed out 22yr old bushings front and rear. adj traction rods. toe rods and lower control arms. got the whole tire planted now so I can launch harder. motor is still lacking something. it just doesn't pull up top like it should.
I've only built one to date. With the tm/tf sticky. From a old 650dp. Never been all that involved or built an all out. Just the basics. And car still runs good. A stock 5.3 with bout 8-10psi.
I want use a 650 for my 4.8.
I think that will be enuff for 500-600rw thru built a3/ 12bolt
