Gears & Axles - What driveshaft loop M6 texas speed true duals BMR TQ Arm
Canada204
08-14-2012, 06:36 PM
Like the title says
JUSTINSWS6
08-14-2012, 06:42 PM
Midweat chassis drive shaft saftey loop is da boom! You loose no clearance because it goes up not down.
http://www.midwestchassis.com/driveshafts--loops.html
guppymech
08-14-2012, 06:59 PM
Lakewood DS loop p/n 18022. It goes up in the tunnel area. Don't know about fit with duals or bmr torque arm though. I have one and it's a nice piece, bolts together so you don't have to remove the DS to install it.
http://www.summitracing.com/parts/LAK-18022/Application/?prefilter=1
JUSTINSWS6
08-14-2012, 07:01 PM
Does the nhra approve that one? Since it bolts?
guppymech
08-14-2012, 07:05 PM
Here it says in the first paragraph it NHRA legal.
http://static.summitracing.com/global/images/instructions/lak-18022.pdf
JUSTINSWS6
08-14-2012, 07:08 PM
Ok i couldnt remember the rule on thaf i thought at are local track they said its no good
garygnu
08-14-2012, 07:57 PM
check the ws6 store for DS loops .do you want a cross member with a DS loop ?
dodson55
08-16-2012, 02:17 PM
i built my own dont know if it would pass nhra or not but i have snapped driveshafts with it and it works so im happy with it
onfire
08-16-2012, 02:26 PM
Never used it. $70
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
