hows this setup for the track
Lt1 350 bored to 355
Heads ported and polished (flows: intake 278, exhaust 197)
CC Cam 230/242, .510 lift,113 lobe separation
Comp Cams Pro Magnum 1.6 roller rockers w/7/16" studs
Comp Cams 987 Dual Valve Springs
SI Silverline Series Valves,(2.00" intake and 1.97 Exhaust)
Eagle H beem connecting rods
JE Forged Nitrous Pistons
Crane Hardened Push Rods
shifting near 6500
Ported Intake Runners to match Heads
K&N Cold Air Induction
Relocated Air Intake Temp Sensor
FMS 30lbs. Injectors
Hooker Headers Long tubes.
3" Custom Made Y Pipe
Borla 3"
PI VIG 3500 Stall Converter
Suspension
Rear Lower Control Arms
Sub Frame Connectors (welded)
GMS Strut Tower Brace
Adjustable kyb gas shocks and new coils.
Rear end is out of an 02 SS with 4.10s
seem solid??
and the shift point
shifting near 6500
Borla 3"
Suspension
seem solid??
and the shift point
Granted, it has no place on a drag car along with most of the handling mods.
For nitrous I wouldn't worry about a special grind unless you are spraying a big shot...
