using truck computer in ls swap???
Old 08-16-2012, 09:14 PM
383lt1ta's Avatar
Default using truck computer in ls swap???
I'm doing an ls6 swap into my lt1 TA. The computer that I got with my harness, turned to be bad, and I cannot find a computer for a car locally. I have researched that 1999-2000 truck computers are the same part numbers as fbody ones, but have been told sometimes they have problem reflashing them and getting them to work in the fbody. Do I need to have any concerns? Thanks
Old 08-16-2012, 11:12 PM
2xLS1's Avatar
Any blue/red connector non 97-98 PCM should work.
Old 08-16-2012, 11:38 PM
Nemesis350's Avatar
i got a pcm in my car that was originally in a truck. it works fine but it took a while to get it married to my vin, and it burned several hpt credits.
Old 08-17-2012, 12:56 AM
MontecarloDrag's Avatar
They are basically the same. I have flashed several of them from F-Body to truck and viceversa without issues.
That PCM is the most forgiving, it's difficult to damage it if you are careful.
Even the truck's OS can work with a car swap, you just need a little more tuning work.
Find the best OS for your application and flash it over, you'll be ok
Old 08-17-2012, 04:20 PM
383lt1ta's Avatar
Thanks for the help. Got a red/blue out a truck and got the tune put in it. Now little more work to the fuel system and I'll be ready.
Old 08-20-2012, 09:15 PM
1fastkingcab's Avatar
Just wondering, but could the truck OS be used along with some kind of toggle switch to flip back & fourth between Tow/Haul mode for some kind of an on the fly street / strip mode?
Old 08-22-2012, 10:37 AM
mike13's Avatar
No, sorry only one per customer The pcm only holds the latest update to the pcm.
Old 08-22-2012, 08:58 PM
Yes, it's possible but you need the BCM to hook the toggle switch. There is no PCM input to activate a tow/haul mode, it need to be acivated using Class 2 comms. The BCM sends the signal when the proper pin is grounded
Quick Reply: using truck computer in ls swap???
